Problems |
Catalog: Freshservice
Schema: Freshservice
Primary Keys: id
This is a read-only table. The Freshservice API may not support changing the data or the Invantive UniversalSQL driver for Freshservice does not cover it. In the latter case, please use the table NativePlatformScalarRequests to upload data to the Freshservice API.
Table Columns
The columns of the table Problems are shown below. Each column has an SQL data type.
Name |
Data Type |
Label |
Required |
Documentation |
agent_id |
int64 |
category |
string |
created_at |
datetime |
Date/time at which the record was created. |
department_id |
int64 |
description_text |
string |
description |
string |
due_by |
datetime |
group_id |
int64 |
id |
int64 |
impact |
int16 |
item_category |
string |
known_error |
boolean |
priority |
int16 |
requester_id |
int64 |
status |
int16 |
sub_category |
string |
subject |
string |
updated_at |
datetime |
Date/time at which the record was last updated. |
11-12-2024 09:11 Version 24.0.491-PROD+5130
