Calls: HubSpot Calls |
ListRead a page of calls. Control what is returned via the `properties` query param.
Catalog: BETA
Schema: Basic
Label: Calls
Retrieve: true
Insert: true
Update: false
Delete: false
The following parameters can be used to control the behaviour of the table function Calls. A value must be provided at all times for required parameters, but optional parameters in general do not need to have a value and the execution will default to a pre-defined behaviour. Values can be specified by position and by name. In both cases, all parameters not specified will be evaluated using their default values.
Name |
Data Type |
Required |
Default Value |
Documentation |
after |
string |
archived |
boolean |
The columns of the table function Calls are shown below. Each column has an SQL data type. A new non-null value must be provided for every required column at all times during insert.
Name |
Data Type |
Label |
Required |
Documentation |
archived |
boolean |
Archived |
archivedAt |
datetime |
Archived at |
associations |
string |
Associations |
createdAt |
datetime |
Created at |
id |
string |
ID |
prop_hs_activity_type |
string |
Activity Type |
prop_hs_all_accessible_team_ids |
string |
All Accessible Team IDs |
prop_hs_all_assigned_business_unit_ids |
string |
All Assigned Business Unit IDs |
prop_hs_all_owner_ids |
string |
All Owner IDs |
prop_hs_all_team_ids |
string |
All Team IDs |
prop_hs_at_mentioned_owner_ids |
string |
At Mentioned Owner IDs |
prop_hs_attachment_ids |
string |
Attachment IDs |
prop_hs_body_preview_html |
string |
Body Preview (HTML) |
prop_hs_body_preview_is_truncated |
boolean |
Body Preview is Truncated |
prop_hs_body_preview |
string |
Body Preview |
prop_hs_call_app_id |
decimal |
Call App ID |
prop_hs_call_authed_url_provider |
string |
Call Authenticated URL Provider |
prop_hs_call_body |
string |
Call Body |
prop_hs_call_callee_object_id |
decimal |
Call Callee Object ID |
prop_hs_call_callee_object_type |
string |
Call Callee Object Type |
prop_hs_call_deal_stage_during_call |
string |
Call Deal Stage during Call |
prop_hs_call_direction |
string |
Call Direction |
prop_hs_call_disposition |
string |
Call Disposition |
prop_hs_call_duration |
decimal |
Call Duration |
prop_hs_call_external_account_id |
string |
Call External Account ID |
prop_hs_call_external_id |
string |
Call External ID |
prop_hs_call_from_number_nickname |
string |
Call From Number Nickname |
prop_hs_call_from_number |
string |
Call From Number |
prop_hs_call_has_transcript |
boolean |
Call Has Transcript |
prop_hs_call_has_voicemail |
string |
Call Has Voicemail |
prop_hs_call_location |
string |
{res:itgen_hubspot_prop_hs_call_location} |
prop_hs_call_meeting_id |
string |
{res:itgen_hubspot_prop_hs_call_meeting_id} |
prop_hs_call_ms_teams_payload |
string |
{res:itgen_hubspot_prop_hs_call_ms_teams_payload} |
prop_hs_call_phone_number_source |
string |
{res:itgen_hubspot_prop_hs_call_phone_number_source} |
prop_hs_call_primary_deal |
string |
Call Primary Deal |
prop_hs_call_recording_url |
string |
Call Recording URL |
prop_hs_call_routing_strategy_type |
string |
{res:itgen_hubspot_prop_hs_call_routing_strategy_type} |
prop_hs_call_source |
string |
Call Source |
prop_hs_call_status |
string |
Call Status |
prop_hs_call_summary_execution_id |
string |
{res:itgen_hubspot_prop_hs_call_summary_execution_id} |
prop_hs_call_summary |
string |
{res:itgen_hubspot_prop_hs_call_summary} |
prop_hs_call_title |
string |
Call Title |
prop_hs_call_to_number_nickname |
string |
Call To Number Nickname |
prop_hs_call_to_number |
string |
Call To Number |
prop_hs_call_transcript_audio_num_channels |
decimal |
Call Transcript Audio Number of Channels |
prop_hs_call_transcript_tracked_terms |
string |
Call Transcript Tracked Terms |
prop_hs_call_transcription_id |
decimal |
Call Transcription ID |
prop_hs_call_unified_phone_number_id |
decimal |
{res:itgen_hubspot_prop_hs_call_unified_phone_number_id} |
prop_hs_call_video_meeting_type |
string |
{res:itgen_hubspot_prop_hs_call_video_meeting_type} |
prop_hs_call_video_recording_url |
string |
Call Video Recording URL |
prop_hs_call_zoom_meeting_uuid |
string |
Call Zoom Meeting UUID |
prop_hs_calls_service_call_id |
decimal |
Calls Service Call ID |
prop_hs_campaign_guid |
string |
{res:itgen_hubspot_prop_hs_campaign_guid} |
prop_hs_connected_count |
decimal |
Connected Count |
prop_hs_created_by_user_id |
decimal |
Created by User ID |
prop_hs_created_by |
decimal |
Created by |
prop_hs_createdate |
datetime |
Created at |
prop_hs_engagement_source_id |
string |
Engagement Source ID |
prop_hs_engagement_source |
string |
Engagement Source |
prop_hs_follow_up_action |
string |
Follow-up Action |
prop_hs_gdpr_deleted |
boolean |
GDPR Deleted |
prop_hs_lastmodifieddate |
datetime |
Last Modified Date |
prop_hs_merged_object_ids |
string |
Merged Object IDs |
prop_hs_modified_by |
decimal |
Modified by |
prop_hs_object_id |
decimal |
Object ID |
prop_hs_object_source_detail_1 |
string |
{res:itgen_hubspot_prop_hs_object_source_detail_1} |
prop_hs_object_source_detail_2 |
string |
{res:itgen_hubspot_prop_hs_object_source_detail_2} |
prop_hs_object_source_detail_3 |
string |
{res:itgen_hubspot_prop_hs_object_source_detail_3} |
prop_hs_object_source_id |
string |
{res:itgen_hubspot_prop_hs_object_source_id} |
prop_hs_object_source_label |
string |
{res:itgen_hubspot_prop_hs_object_source_label} |
prop_hs_object_source_user_id |
decimal |
{res:itgen_hubspot_prop_hs_object_source_user_id} |
prop_hs_object_source |
string |
{res:itgen_hubspot_prop_hs_object_source} |
prop_hs_product_name |
string |
Product Name |
prop_hs_queue_membership_ids |
string |
Queue Membership IDs |
prop_hs_read_only |
boolean |
Read-only |
prop_hs_shared_team_ids |
string |
{res:itgen_hubspot_prop_hs_shared_team_ids} |
prop_hs_shared_user_ids |
string |
{res:itgen_hubspot_prop_hs_shared_user_ids} |
prop_hs_timestamp |
datetime |
Timestamp |
prop_hs_unique_creation_key |
string |
Unique Creation Key |
prop_hs_unique_id |
string |
Unique ID |
prop_hs_unknown_visitor_conversation |
boolean |
Unknown Visitor Conversation |
prop_hs_updated_by_user_id |
decimal |
Updated by User ID |
prop_hs_user_ids_of_all_notification_followers |
string |
User IDs of All Notification Followers |
prop_hs_user_ids_of_all_notification_unfollowers |
string |
User IDs of All Notification Unfollowers |
prop_hs_user_ids_of_all_owners |
string |
User IDs of All Owners |
prop_hs_voicemail_count |
decimal |
Voicemail Count |
prop_hs_was_imported |
boolean |
Was Imported |
prop_hubspot_owner_assigneddate |
datetime |
Owner Assigned Date |
prop_hubspot_owner_id |
string |
Owner ID |
prop_hubspot_team_id |
string |
Team ID |
updatedAt |
datetime |
Updated at |
HubSpot API Data Model
