HubSpot Forums
Navigation: Catalog: BETA > Schemas > Schema: Users > Tables
Users
Retrieves a list of users from an accountRetrieves a list of users from an account
Catalog: BETA
Schema: Users
Label: {res:itgen_hubspot_users_plural}
Retrieve: true
Insert: true
Update: false
Delete: false
The following parameters can be used to control the behaviour of the table function Users. A value must be provided at all times for required parameters, but optional parameters in general do not need to have a value and the execution will default to a pre-defined behaviour. Values can be specified by position and by name. In both cases, all parameters not specified will be evaluated using their default values.
Name
Data Type
Required
Default Value
Documentation
after
string
Results will display maximum 100 users per page. Additional results will be on the next page.
The columns of the table function Users are shown below. Each column has an SQL data type. A new non-null value must be provided for every required column at all times during insert.
Name
Data Type
Label
Required
Documentation
email
string
Email
The user's email
firstName
string
First Name
id
string
ID
The user's unique ID
lastName
string
Last Name
primaryTeamId
string
Primary Team ID
The user's primary team
roleId
string
Role ID
The user's role
sendWelcomeEmail
boolean
{res:itgen_hubspot_sendwelcomeemail}
superAdmin
boolean
{res:itgen_hubspot_superadmin}
Disclaimer
