HubSpot Forums
Navigation: Catalog: BlogSettings > Schemas > Schema: Advanced > Tables
CmsVBlogSettingsSettingsByBlogIdRevisions_ObjectPublicAccessRulesRevisionId
Get a specific blog revisionGet a specific blog revision.
Schema: Advanced
The following parameters can be used to control the behaviour of the table function CmsVBlogSettingsSettingsByBlogIdRevisions_ObjectPublicAccessRulesRevisionId. A value must be provided at all times for required parameters, but optional parameters in general do not need to have a value and the execution will default to a pre-defined behaviour. Values can be specified by position and by name. In both cases, all parameters not specified will be evaluated using their default values.
Name
Data Type
Required
Default Value
Documentation
blogId
revisionId
The columns of the table function CmsVBlogSettingsSettingsByBlogIdRevisions_ObjectPublicAccessRulesRevisionId are shown below. Each column has an SQL data type.
Name
Data Type
Label
Required
Documentation
absoluteUrl
varchar2
Blog's root URL
allowComments
char
Boolean determining whether or not this blog allows public comments.
created
datetime
Created at
The timestamp (ISO8601 format) when this blog was created.
deletedAt
datetime
Deleted at
The timestamp (ISO8601 format) when this Blog was deleted.
description
varchar2
Description
The Description of this Blog.
htmlTitle
varchar2
Title (HTML)
The html title of this Blog.
id_2
varchar2
ID (Alternate 2)
id
varchar2
ID
The unique ID of the Blog.
language
varchar2
Language
The explicitly defined language of the Blog. If null, the Blog will default to the language of the Domain.
listingPageId
varchar2
name
varchar2
Name
The internal name of the blog.
publicAccessRulesEnabled
char
Public Access Rules Enabled
publicTitle
varchar2
The public title of this Blog.
slug
varchar2
Slug
The path of the this blog. This field is appended to the domain to construct the url of this blog.
translatedFromId
varchar2
Translated from ID
ID of the primary Blog this object was translated from.
updated
datetime
Updated at
The timestamp (ISO8601 format) when this blog was updated.
updatedAt
datetime
Updated at
user_email
varchar2
User Email
The email address of the user.
user_fullName
varchar2
User Full Name
The first and last name of the User.
user_id
varchar2
User ID
The unique ID of the User.
Disclaimer
