HubSpot Forums
Navigation: Catalog: ManageEventDefinitions > Schemas
EventDefinitionByName
Retrieve a custom event definitionFetch a single custom event definition by name.
Schema: Basic
The following parameters can be used to control the behaviour of the table function EventDefinitionByName. A value must be provided at all times for required parameters, but optional parameters in general do not need to have a value and the execution will default to a pre-defined behaviour. Values can be specified by position and by name. In both cases, all parameters not specified will be evaluated using their default values.
Name
Data Type
Required
Default Value
Documentation
eventName
The columns of the table function EventDefinitionByName are shown below. Each column has an SQL data type.
Name
Data Type
Label
Required
Documentation
archived
char
Archived
comboEventRules_operationType
varchar2
createdAt
datetime
Created at
createdUserId
int32
Created User ID
customMatchingId_primaryObjectRule_eventPropertyName
varchar2
customMatchingId_primaryObjectRule_targetObjectPropertyName
varchar2
description
varchar2
Description
detailTemplate
varchar2
Detail Template
fullyQualifiedName
varchar2
Fully Qualified Name
headerTemplate
varchar2
Header Template
id
varchar2
ID
labels_plural
varchar2
Labels Plural
labels_singular
varchar2
Labels Singular
name
varchar2
Name
objectTypeId
varchar2
Ojbect Type ID
primaryObject
varchar2
primaryObjectId
varchar2
trackingType
varchar2
updatedAt
datetime
Updated at
updatedUserId
int32
Updated User ID
Disclaimer
