HubSpot Forums
Navigation: Catalog: MarketingEvents > Schemas > Schema: Settings > Tables
MarketingEventsByAppIdSettings
Retrieve the application settingsRetrieve the current settings for the application.
Schema: Settings
The following parameters can be used to control the behaviour of the table function MarketingEventsByAppIdSettings. A value must be provided at all times for required parameters, but optional parameters in general do not need to have a value and the execution will default to a pre-defined behaviour. Values can be specified by position and by name. In both cases, all parameters not specified will be evaluated using their default values.
Name
Data Type
Required
Default Value
Documentation
appId
The columns of the table function MarketingEventsByAppIdSettings are shown below. Each column has an SQL data type.
Name
Data Type
Label
Required
Documentation
appId
int32
App ID
The id of the application the settings are for
eventDetailsUrl
varchar2
Event Details (URL)
The url that will be used to fetch marketing event details by id
Disclaimer
