MarketingEventsByAppIdSettings |
Retrieve the application settingsRetrieve the current settings for the application.
Catalog: MarketingEvents3
Schema: Settings
Label: {res:itgen_hubspot_marketingeventsbyappidsettings_plural}
The following parameters can be used to control the behaviour of the table function MarketingEventsByAppIdSettings. A value must be provided at all times for required parameters, but optional parameters in general do not need to have a value and the execution will default to a pre-defined behaviour. Values can be specified by position and by name. In both cases, all parameters not specified will be evaluated using their default values.
Name |
Data Type |
Required |
Default Value |
Documentation |
appId |
int32 |
The id of the application to retrieve the settings for. |
The columns of the table function MarketingEventsByAppIdSettings are shown below. Each column has an SQL data type.
Name |
Data Type |
Label |
Required |
Documentation |
appId |
int32 |
App ID |
The id of the application the settings are for |
eventDetailsUrl |
string |
Event Details (URL) |
The url that will be used to fetch marketing event details by id |
HubSpot API Data Model
