HubSpot Forums
Navigation: Catalog: Posts > Schemas > Schema: Basic > Tables
BlogPostAttachedStylesheetsByObjectId
Retrieve a blog postRetrieve a blog post by the post ID.
Catalog: Posts
Schema: Basic
The following parameters can be used to control the behaviour of the table function BlogPostAttachedStylesheetsByObjectId. A value must be provided at all times for required parameters, but optional parameters in general do not need to have a value and the execution will default to a pre-defined behaviour. Values can be specified by position and by name. In both cases, all parameters not specified will be evaluated using their default values.
Name
Data Type
Required
Default Value
Documentation
archived
objectId
The blog post ID
property
The columns of the table function BlogPostAttachedStylesheetsByObjectId are shown below. Each column has an SQL data type.
Name
Data Type
Label
Required
Documentation
abStatus
varchar2
A/B Status
abTestId
varchar2
A/B Test ID
archivedAt
int64
Archived at
archivedInDashboard
char
Archived in Dashboard
authorName
varchar2
Author Name
blogAuthorId
varchar2
Blog Author ID
campaign
varchar2
Campaign
categoryId
int32
Category ID
contentGroupId
varchar2
Content Group ID
contentTypeCategory
varchar2
Content Type Category
created
datetime
Created at
createdById
varchar2
Created by ID
currentlyPublished
char
Currently Published
currentState
varchar2
Current State
domain
varchar2
Domain
dynamicPageDataSourceId
varchar2
Dynamic Page Data Source ID
dynamicPageDataSourceType
int32
Dynamic Page Data Source Type
dynamicPageHubDbTableId
varchar2
enableDomainStylesheets
char
Enable Domain Stylesheets
enableGoogleAmpOutputOverride
char
enableLayoutStylesheets
char
Enable Layout Stylesheets
featuredImage
varchar2
Featured Image
featuredImageAltText
varchar2
Featured Image Alternate Text
folderId
varchar2
Folder ID
footerHtml
varchar2
Footer (HTML)
headHtml
varchar2
Head (HTML)
htmlTitle
varchar2
Title (HTML)
id
varchar2
ID
includeDefaultCustomCss
char
Include Default Custom CSS
language
varchar2
Language
layoutSections
varchar2
Layout Sections
linkRelCanonicalUrl
varchar2
Link Rel Canonical (URL)
mabExperimentId
varchar2
MAB Experiment ID
metaDescription
varchar2
Meta Description
name
varchar2
Name
pageExpiryDate
int64
Page Expiry Date
pageExpiryEnabled
char
Page Expiry Enabled
pageExpiryRedirectId
int64
Page Expiry Redirect ID
varchar2
Page Expiry Redirect (URL)
password
varchar2
Password
postBody
varchar2
Post Body
postSummary
varchar2
Post Summary
publicAccessRulesEnabled
char
Public Access Rules Enabled
publishDate
datetime
Publish Date
publishImmediately
char
Publish Immediately
rssBody
varchar2
RSS Body
rssSummary
varchar2
RSS Summary
slug
varchar2
Slug
state
varchar2(25)
State
tagIds
varchar2
Tag IDs
themeSettingsValues
varchar2
Theme Setting Values
translatedFromId
varchar2
Translated from ID
translations
varchar2
Translations
updated
datetime
Updated at
updatedById
varchar2
Updated by ID
url
varchar2
URL
useFeaturedImage
char
Use Featured Image
widgetContainers
varchar2
Widget Containers
widgets
varchar2
Widgets
Disclaimer
