CmsVBlogsPostsByObjectIdRevisions_ObjectTagIdsRevisionId |
Retrieve a previous version of a blog postRetrieve a previous version of a blog post.
Catalog: Posts
Schema: Revisions
The following parameters can be used to control the behaviour of the table function CmsVBlogsPostsByObjectIdRevisions_ObjectTagIdsRevisionId. A value must be provided at all times for required parameters, but optional parameters in general do not need to have a value and the execution will default to a pre-defined behaviour. Values can be specified by position and by name. In both cases, all parameters not specified will be evaluated using their default values.
Name |
Data Type |
Required |
Default Value |
Documentation |
objectId |
The blog post ID |
revisionId |
The ID of the revision to retrieve |
The columns of the table function CmsVBlogsPostsByObjectIdRevisions_ObjectTagIdsRevisionId are shown below. Each column has an SQL data type.
Name |
Data Type |
Label |
Required |
Documentation |
abStatus |
varchar2 |
A/B Status |
abTestId |
varchar2 |
A/B Test ID |
archivedAt |
int64 |
Archived at |
archivedInDashboard |
char |
Archived in Dashboard |
authorName |
varchar2 |
Author Name |
blogAuthorId |
varchar2 |
Blog Author ID |
campaign |
varchar2 |
Campaign |
categoryId |
int32 |
Category ID |
contentGroupId |
varchar2 |
Content Group ID |
contentTypeCategory |
varchar2 |
Content Type Category |
created |
datetime |
Created at |
createdById |
varchar2 |
Created by ID |
currentlyPublished |
char |
Currently Published |
currentState |
varchar2 |
Current State |
domain |
varchar2 |
Domain |
dynamicPageDataSourceId |
varchar2 |
Dynamic Page Data Source ID |
dynamicPageDataSourceType |
int32 |
dynamicPageHubDbTableId |
varchar2 |
enableDomainStylesheets |
char |
Enable Domain Stylesheets |
char |
enableLayoutStylesheets |
char |
Enable Layout Stylesheets |
featuredImage |
varchar2 |
Featured Image |
featuredImageAltText |
varchar2 |
folderId |
varchar2 |
Folder ID |
footerHtml |
varchar2 |
Footer (HTML) |
headHtml |
varchar2 |
Head (HTML) |
htmlTitle |
varchar2 |
Title (HTML) |
id_2 |
varchar2 |
ID (Alternate 2) |
id |
varchar2 |
ID |
includeDefaultCustomCss |
char |
Include Default Custom CSS |
language |
varchar2 |
Language |
layoutSections |
varchar2 |
Layout Sections |
linkRelCanonicalUrl |
varchar2 |
Link Rel Canonical (URL) |
mabExperimentId |
varchar2 |
MAB Experiment ID |
metaDescription |
varchar2 |
Meta Description |
name |
varchar2 |
Name |
pageExpiryDate |
int64 |
Page Expiry Date |
pageExpiryEnabled |
char |
Page Expiry Enabled |
pageExpiryRedirectId |
int64 |
Page Expiry Redirect ID |
pageExpiryRedirectUrl |
varchar2 |
Page Expiry Redirect (URL) |
password |
varchar2 |
Password |
postBody |
varchar2 |
Post Body |
postSummary |
varchar2 |
Post Summary |
publicAccessRulesEnabled |
char |
Public Access Rules Enabled |
publishDate |
datetime |
Publish Date |
publishImmediately |
char |
Publish Immediately |
rssBody |
varchar2 |
RSS Body |
rssSummary |
varchar2 |
RSS Summary |
slug |
varchar2 |
Slug |
state |
varchar2(25) |
State |
TEXT |
int64 |
Text |
themeSettingsValues |
varchar2 |
Theme Setting Values |
translatedFromId |
varchar2 |
Translated from ID |
translations |
varchar2 |
Translations |
updated |
datetime |
Updated at |
updatedAt |
datetime |
Updated at |
updatedById |
varchar2 |
Updated by ID |
url |
varchar2 |
URL |
useFeaturedImage |
char |
Use Featured Image |
user_email |
varchar2 |
User Email |
The email address of the user. |
user_fullName |
varchar2 |
User Full Name |
The first and last name of the User. |
user_id |
varchar2 |
User ID |
The unique ID of the User. |
widgetContainers |
varchar2 |
Widget Containers |
widgets |
varchar2 |
Widgets |
