BlogPostPublicAccessRulesByObjectId |
Retrieve a Blog PostRetrieve the Blog Post object identified by the id in the path.
Catalog: Posts3
Schema: BlogPosts
Label: {res:itgen_hubspot_blogpostpublicaccessrulesbyobjectid_plural}
The following parameters can be used to control the behaviour of the table function BlogPostPublicAccessRulesByObjectId. A value must be provided at all times for required parameters, but optional parameters in general do not need to have a value and the execution will default to a pre-defined behaviour. Values can be specified by position and by name. In both cases, all parameters not specified will be evaluated using their default values.
Name |
Data Type |
Required |
Default Value |
Documentation |
archived |
boolean |
Specifies whether to return deleted Blog Posts. Defaults to `false`. |
objectId |
string |
The Blog Post id. |
property |
string |
The columns of the table function BlogPostPublicAccessRulesByObjectId are shown below. Each column has an SQL data type.
Name |
Data Type |
Label |
Required |
Documentation |
abStatus |
string |
A/B Status |
abTestId |
string |
A/B Test ID |
archivedAt |
int64 |
Archived at |
archivedInDashboard |
boolean |
Archived in Dashboard |
authorName |
string |
Author Name |
blogAuthorId |
string |
Blog Author ID |
campaign |
string |
Campaign |
categoryId |
int32 |
Category ID |
ID of the type of object this is. |
contentGroupId |
string |
Content Group ID |
contentTypeCategory |
string |
Content Type Category |
created |
datetime |
Created at |
createdById |
string |
Created by ID |
currentlyPublished |
boolean |
Currently Published |
currentState |
string |
Current State |
domain |
string |
Domain |
dynamicPageDataSourceId |
string |
Dynamic Page Data Source ID |
dynamicPageDataSourceType |
int32 |
dynamicPageHubDbTableId |
string |
{res:itgen_hubspot_dynamicpagehubdbtableid} |
enableDomainStylesheets |
boolean |
Enable Domain Stylesheets |
boolean |
enableLayoutStylesheets |
boolean |
Enable Layout Stylesheets |
featuredImage |
string |
Featured Image |
featuredImageAltText |
string |
folderId |
string |
Folder ID |
footerHtml |
string |
Footer (HTML) |
headHtml |
string |
Head (HTML) |
htmlTitle |
string |
Title (HTML) |
id |
string |
ID |
includeDefaultCustomCss |
boolean |
Include Default Custom CSS |
language |
string |
Language |
layoutSections |
string |
Layout Sections |
linkRelCanonicalUrl |
string |
Link Rel Canonical (URL) |
mabExperimentId |
string |
MAB Experiment ID |
metaDescription |
string |
Meta Description |
name |
string |
Name |
pageExpiryDate |
int64 |
Page Expiry Date |
pageExpiryEnabled |
boolean |
Page Expiry Enabled |
pageExpiryRedirectId |
int64 |
Page Expiry Redirect ID |
pageExpiryRedirectUrl |
string |
Page Expiry Redirect (URL) |
password |
string |
Password |
postBody |
string |
Post Body |
postSummary |
string |
Post Summary |
publicAccessRulesEnabled |
boolean |
Public Access Rules Enabled |
publishDate |
datetime |
Publish Date |
publishImmediately |
boolean |
Publish Immediately |
rssBody |
string |
RSS Body |
rssSummary |
string |
RSS Summary |
slug |
string |
Slug |
state |
string(25) |
State |
tagIds |
string |
Tag IDs |
themeSettingsValues |
string |
Theme Setting Values |
translatedFromId |
string |
Translated from ID |
translations |
string |
Translations |
updated |
datetime |
Updated at |
updatedById |
string |
Updated by ID |
url |
string |
URL |
useFeaturedImage |
boolean |
Use Featured Image |
widgetContainers |
string |
Widget Containers |
widgets |
string |
Widgets |
