HubSpot Forums
Navigation: Catalog: Posts3 > Schemas
BlogPostRevisionsByObjectId
Retrieves all the previous versions of a blog postRetrieves all the previous versions of a blog post.
Catalog: Posts3
Schema: BlogPosts
Label: {res:itgen_hubspot_blogpostrevisionsbyobjectid_plural}
The following parameters can be used to control the behaviour of the table function BlogPostRevisionsByObjectId. A value must be provided at all times for required parameters, but optional parameters in general do not need to have a value and the execution will default to a pre-defined behaviour. Values can be specified by position and by name. In both cases, all parameters not specified will be evaluated using their default values.
Name
Data Type
Required
Default Value
Documentation
after
string
The cursor token value to get the next set of results. You can get this from the `paging.next.after` JSON property of a paged response containing more results.
before
string
objectId
string
The Blog Post id.
The columns of the table function BlogPostRevisionsByObjectId are shown below. Each column has an SQL data type.
Name
Data Type
Label
Required
Documentation
id
string
ID
The id of the version.
object_abStatus
string
Object A/B Status
object_abTestId
string
Object A/B Test ID
object_archivedAt
int64
{res:itgen_hubspot_object_archivedat}
object_archivedInDashboard
boolean
Object Archived in Dashboard
object_authorName
string
Object Author Name
object_blogAuthorId
string
Object Blog Author ID
object_campaign
string
Object Campaign
object_categoryId
int32
Object Category ID
ID of the type of object this is.
object_contentGroupId
string
Object Content Group ID
object_contentTypeCategory
string
Object Content Type Category
object_created
datetime
Object Created at
object_createdById
string
Object Created by ID
object_currentlyPublished
boolean
Object Currently Published
object_currentState
string
Object Current State
object_domain
string
Object Domain
object_dynamicPageDataSourceId
string
Object Dynamic Page Data Source ID
object_dynamicPageDataSourceType
int32
Object Dynamic Page Data Source Type
object_dynamicPageHubDbTableId
string
{res:itgen_hubspot_object_dynamicpagehubdbtableid}
object_enableDomainStylesheets
boolean
Object Enable Domain Stylesheet
object_enableGoogleAmpOutputOverride
boolean
Object Enable Google AMP Output Override
object_enableLayoutStylesheets
boolean
Object Enable Layout Stylesheets
object_featuredImage
string
Object Featured Image
object_featuredImageAltText
string
Object Featured Image Alternate Text
object_folderId
string
Object Folder ID
object_footerHtml
string
Object Footer (HTML)
object_headHtml
string
Object Head (HTML)
object_htmlTitle
string
Object Title (HTML)
object_id
string
Object ID
object_includeDefaultCustomCss
boolean
Object Include Default Custom CSS
object_language
string
Object Language
object_layoutSections
string
Object Layout Sections
object_linkRelCanonicalUrl
string
Object Link Rel Canonical (URL)
object_mabExperimentId
string
Object MAB Experiment ID
object_metaDescription
string
Object Meta Description
object_name
string
Object Name
object_pageExpiryDate
int64
Object Page Expiry Date
object_pageExpiryEnabled
boolean
Object Page Expiry Enabled
object_pageExpiryRedirectId
int64
Object Page Expiry Redirect ID
object_pageExpiryRedirectUrl
string
Object Page Expiry Redirect URL
object_password
string
Object Password
object_postBody
string
Object Post Body
object_postSummary
string
Object Post Summary
object_publicAccessRulesEnabled
boolean
Object Public Access Rules Enabled
object_publishDate
datetime
Object Publish Date
object_publishImmediately
boolean
Object Publish Immediately
object_rssBody
string
Object RSS Body
object_rssSummary
string
Object RSS Summary
object_slug
string
Object Slug
object_state
string(25)
Object State
object_tagIds
string
Object Tag IDs
object_themeSettingsValues
string
Object Theme Setting Values
object_translatedFromId
string
Object Translated from ID
object_translations
string
Object Translations
object_updated
datetime
Object Updated at
object_updatedById
string
Object Updated by ID
object_url
string
Object URL
object_useFeaturedImage
boolean
Object Use Featured Image
object_widgetContainers
string
Object Widget Containers
object_widgets
string
Object Widgets
updatedAt
datetime
Updated at
user_email
string
User Email
The email address of the user.
user_fullName
string
User Full Name
The first and last name of the User.
user_id
string
User ID
The unique ID of the User.
Disclaimer
