Products: HubSpot Products |
ListRead a page of products. Control what is returned via the `properties` query param.
Catalog: Products3
Schema: Basic
Label: Products
Retrieve: true
Insert: true
Update: false
Delete: false
The following parameters can be used to control the behaviour of the table function Products. A value must be provided at all times for required parameters, but optional parameters in general do not need to have a value and the execution will default to a pre-defined behaviour. Values can be specified by position and by name. In both cases, all parameters not specified will be evaluated using their default values.
Name |
Data Type |
Required |
Default Value |
Documentation |
after |
string |
archived |
boolean |
The columns of the table function Products are shown below. Each column has an SQL data type. A new non-null value must be provided for every required column at all times during insert.
Name |
Data Type |
Label |
Required |
Documentation |
archived |
boolean |
Archived |
archivedAt |
datetime |
Archived at |
associations |
string |
Associations |
createdAt |
datetime |
Created at |
id |
string |
ID |
prop_amount |
decimal |
Amount |
prop_createdate |
datetime |
Created at |
prop_description |
string |
Description |
prop_discount |
decimal |
Discount |
prop_hs_all_accessible_team_ids |
string |
All Accessible Team IDs |
prop_hs_all_assigned_business_unit_ids |
string |
All Assigned Business Unit IDs |
prop_hs_all_owner_ids |
string |
All Owner IDs |
prop_hs_all_team_ids |
string |
All Team IDs |
prop_hs_avatar_filemanager_key |
string |
Avatar Filemanager Key |
prop_hs_cost_of_goods_sold |
decimal |
Cost of Goods Sold |
prop_hs_created_by_user_id |
decimal |
Created by User ID |
prop_hs_createdate |
datetime |
Created at |
prop_hs_discount_percentage |
decimal |
Discount Percentage |
prop_hs_folder_id |
decimal |
Folder ID |
prop_hs_images |
string |
Images |
prop_hs_lastmodifieddate |
datetime |
Last Modified Date |
prop_hs_merged_object_ids |
string |
Merged Object IDs |
prop_hs_object_id |
decimal |
Object ID |
prop_hs_object_source_detail_1 |
string |
{res:itgen_hubspot_prop_hs_object_source_detail_1} |
prop_hs_object_source_detail_2 |
string |
{res:itgen_hubspot_prop_hs_object_source_detail_2} |
prop_hs_object_source_detail_3 |
string |
{res:itgen_hubspot_prop_hs_object_source_detail_3} |
prop_hs_object_source_id |
string |
{res:itgen_hubspot_prop_hs_object_source_id} |
prop_hs_object_source_label |
string |
{res:itgen_hubspot_prop_hs_object_source_label} |
prop_hs_object_source_user_id |
decimal |
{res:itgen_hubspot_prop_hs_object_source_user_id} |
prop_hs_object_source |
string |
{res:itgen_hubspot_prop_hs_object_source} |
prop_hs_product_type |
string |
Product Type |
prop_hs_read_only |
boolean |
Read-only |
prop_hs_recurring_billing_period |
string |
Recurring Billing Period |
prop_hs_recurring_billing_start_date |
datetime |
Recurring Billing Start Date |
prop_hs_shared_team_ids |
string |
{res:itgen_hubspot_prop_hs_shared_team_ids} |
prop_hs_shared_user_ids |
string |
{res:itgen_hubspot_prop_hs_shared_user_ids} |
prop_hs_sku |
string |
SKU |
prop_hs_unique_creation_key |
string |
Unique Creation Key |
prop_hs_updated_by_user_id |
decimal |
Updated by User ID |
prop_hs_url |
string |
URL |
prop_hs_user_ids_of_all_notification_followers |
string |
User IDs of All Notification Followers |
prop_hs_user_ids_of_all_notification_unfollowers |
string |
User IDs of All Notification Unfollowers |
prop_hs_user_ids_of_all_owners |
string |
User IDs of All Owners |
prop_hs_was_imported |
boolean |
Was Imported |
prop_hubspot_owner_assigneddate |
datetime |
Owner Assigned Date |
prop_hubspot_owner_id |
string |
Owner ID |
prop_hubspot_team_id |
string |
Team ID |
prop_name |
string |
Name |
prop_price |
decimal |
Price |
prop_quantity |
decimal |
Quantity |
prop_recurringbillingfrequency |
string |
Recurring Billing Frequency |
prop_tax |
decimal |
Tax |
updatedAt |
datetime |
Updated at |
