HubSpot Forums
Navigation: Catalog: SourceCode > Schemas > Schema: Advanced > Tables
SourceCodeExtractAsyncTasksByTaskIdStatus
Get extraction statusGet the status of an extraction by the `taskId` returned from the initial `extract/async` request.
Catalog: SourceCode
Schema: Advanced
The following parameters can be used to control the behaviour of the table function SourceCodeExtractAsyncTasksByTaskIdStatus. A value must be provided at all times for required parameters, but optional parameters in general do not need to have a value and the execution will default to a pre-defined behaviour. Values can be specified by position and by name. In both cases, all parameters not specified will be evaluated using their default values.
Name
Data Type
Required
Default Value
Documentation
taskId
The columns of the table function SourceCodeExtractAsyncTasksByTaskIdStatus are shown below. Each column has an SQL data type.
Name
Data Type
Label
Required
Documentation
completedAt
datetime
Completed at
The timestamp indicating when the action was completed.
links
varchar2
Links
A map of link names to associated URIs containing documentation about the error or recommended remediation steps
requestedAt
datetime
Requested at
The timestamp indicating when the action was requested.
startedAt
datetime
Started at
The timestamp indicating when the action was started.
status
varchar2
Status
The current status of the action, with possible values: CANCELED, COMPLETE, PENDING, PROCESSING.
Disclaimer
