Users |
Retrieves a list of users from an accountRetrieves a list of users from an account
Catalog: UserProvisioning3
Schema: Users
Label: {res:itgen_hubspot_users_plural}
Retrieve: true
Insert: true
Update: false
Delete: false
The following parameters can be used to control the behaviour of the table function Users. A value must be provided at all times for required parameters, but optional parameters in general do not need to have a value and the execution will default to a pre-defined behaviour. Values can be specified by position and by name. In both cases, all parameters not specified will be evaluated using their default values.
Name |
Data Type |
Required |
Default Value |
Documentation |
after |
string |
Results will display maximum 100 users per page. Additional results will be on the next page. |
The columns of the table function Users are shown below. Each column has an SQL data type. A new non-null value must be provided for every required column at all times during insert.
Name |
Data Type |
Label |
Required |
Documentation |
string |
The user's email |
firstName |
string |
First Name |
id |
string |
ID |
The user's unique ID |
lastName |
string |
Last Name |
primaryTeamId |
string |
Primary Team ID |
The user's primary team |
roleId |
string |
Role ID |
The user's role |
sendWelcomeEmail |
boolean |
{res:itgen_hubspot_sendwelcomeemail} |
superAdmin |
boolean |
{res:itgen_hubspot_superadmin} |
HubSpot API Data Model
