Procedural SQL |
Invantive Procedural SQL (or "PSQL" for short) is a procedural extension on top of Invantive UniversalSQL. It is based on the ISO-standard 9075-4:2016 (SQL/PSM) and extends Invantive UniversalSQL with procedural options like blocks, variables, conditional execution and loops. The procedural code is - together with the Invantive UniversalSQL contained - as a whole into pseudo-code and then executed.
The procedural code does not lean on the procedural options of the platforms being used, so it is easy to retrieve and change data in all supported cloud, file and database platforms. The pre-compiled procedural code does not perform context switches between procedural and SQL logic.
Invantive Control for Excel
