Invantive Script Extensions |
Invantive Data Hub supports Invantive Script in addition to support for both Invantive SQL and native SQL databases. Invantive Script is executed on the device running the program.
The following statements are available on top of the regular Invantive Script statements:
•@@: run a SQL script file from the folder in which the current executing file is loaded.
•@: run a SQL script file from the working directory of the program.
Invantive Data Hub
