Encrypt Connection String |
A connection string can be encrypted with reversible encryption on Windows platforms using the roaming profile key and on other platforms using an Invantive-managed key. The syntax is:
local encrypt connection string ["VALUE"] [label "LABEL"]
The encrypted value can be used for an encrypted connection string in settings.xml. The encrypted value can also be used to assign a variable a value.
Invantive Data Hub
