Products |
Fetches all products you have access to.
Catalog: Tixly
Schema: Product
This is a read-only table function. The Tixly API may not support changing the data or the Invantive SQL driver for Tixly does not cover it. In the latter case, please use the table NativePlatformScalarRequests to upload data to the Tixly API.
The following parameters can be used to control the behaviour of the table function Products. A value must be provided at all times for required parameters, but optional parameters in general do not need to have a value and the execution will default to a pre-defined behaviour. Values can be specified by position and by name. In both cases, all parameters not specified will be evaluated using their default values.
Name |
Data Type |
Required |
Default Value |
Documentation |
SoldFrom |
datetime |
If this is set, then only get sales after this date |
SoldTo |
datetime |
If this is set, then only get sales before this date |
The columns of the table function Products are shown below. Each column has an SQL data type.
Name |
Data Type |
Label |
Required |
Documentation |
Created |
datetime |
Created |
CreatedUTCUnix |
int64 |
Description |
string |
Description |
Edited |
datetime |
Edited |
EditedUTCUnix |
int64 |
GroupingText |
string |
Grouping Text |
Id |
int32 |
ID |
Name |
string |
Name |
Price |
double |
Price |
Vat |
double |
VAT |
22-12-2022 21:15 Version 22.1.101-BETA+3681
