Products_ItemsUserDefinedFields |
Catalog: Autotask
Schema: Products
This is a read-only table. The Autotask API may not support changing the data or the Invantive UniversalSQL driver for Autotask does not cover it. In the latter case, please use the table NativePlatformScalarRequests to upload data to the Autotask API.
Table Columns
The columns of the table Products_ItemsUserDefinedFields are shown below. Each column has an SQL data type.
Name |
Data Type |
Label |
Required |
Documentation |
billingType |
int32 |
Billing Type |
chargeBillingCodeID |
int32 |
Charge Billing Code ID |
defaultInstalledProductCategoryID |
int32 |
Defaul Iinstalled Product Category ID |
defaultVendorID |
int32 |
Default Vendor ID |
description |
string |
Description |
doesNotRequireProcurement |
boolean |
Does not require Procurement |
externalProductID |
string |
External Product ID |
id |
int64 |
ID |
impersonatorCreatorResourceID |
int32 |
Imperonsator Creator Resource ID |
internalProductID |
string |
Internal Product ID |
isActive |
boolean |
Is Active |
isEligibleForRma |
boolean |
Is Eligible for RMA |
isSerialized |
boolean |
Is Serialized |
link |
string |
Link |
manufacturerName |
string |
Manufacturer Name |
manufacturerProductName |
string |
Manufacturer Product Name |
markupRate |
double |
Mark-up Rate |
msrp |
double |
MSRP |
name_1 |
string |
Name |
name |
string |
Name |
periodType |
int32 |
Period Type |
priceCostMethod |
int32 |
Price Cost Method |
productBillingCodeID |
int32 |
Product Billing Code ID |
productCategory |
int32 |
Product Category |
sku |
string |
SKU |
unitCost |
double |
Unit Cost |
unitPrice |
double |
Unit Price |
value |
string |
Value |
vendorProductNumber |
string |
Vendor Product Number |
10-06-2024 18:39 Version 24.1.3-BETA+4689
