Discourse Forums
Navigation: Catalog: Discourse > Schemas > Schema: Posts > Tables
Posts: Discourse Posts
Get a list of the latest posts across topics
Catalog: Discourse
Schema: Posts
Label: Posts
Retrieve: true
Insert: true
Update: false
Delete: false
Table Columns
The columns of the table Posts are shown below. Each column has an SQL data type. A new non-null value must be provided for every required column at all times during insert.
Name
Data Type
Label
Required
Documentation
accepted_answer
char
action_code
varchar2
admin
char
Administrator
avatar_template
varchar2
Avatar Template
avg_time
varchar2
bookmarked
char
Bookmarked
can_accept_answer
char
can_delete
char
Can Delete
can_edit
char
Can Edit
can_recover
varchar2
Can Recover
can_unaccept_answer
char
can_view_edit_history
char
Can View Edit History
can_vote
char
can_wiki
char
Can Wikify
category_id
decimal
Category ID
cooked
varchar2
Cooked
created_at
varchar2
Created at
deleted_at
varchar2
display_username
varchar2
Display User Name
edit_reason
varchar2
hidden
char
Hidden
id
decimal
ID
incoming_link_count
decimal
#Incoming Links
moderator
char
Moderator
name
varchar2
Name
notice_type
varchar2
post_number
decimal
Post Number
post_type
decimal
Post Type
primary_group_flair_bg_color
varchar2
primary_group_flair_color
varchar2
primary_group_flair_url
varchar2
primary_group_name
varchar2
quote_count
decimal
#Quotes
raw
varchar2
Raw
readers_count
int32
reads
decimal
#Reads
reply_count
decimal
#Replies
reply_to_post_number
varchar2
reply_to_user_avatar_template
varchar2
reply_to_user_username
varchar2
reviewable_score_count
int32
reviewable_score_pending_count
int32
score
decimal
Score
staff
char
Staff
static_doc
char
Static Doc
title_is_group
char
topic_html_title
varchar2
Topic HTML Title
topic_id
decimal
Topic ID
topic_slug
varchar2
Topic Slug
topic_title
varchar2
Topic Title
trust_level
decimal
Trust Level
updated_at
varchar2
Updated at
user_deleted
char
User Deleted
user_id
decimal
User ID
user_title
varchar2
username
varchar2
User Name
version
decimal
Version
via_email
char
wiki
char
Wiki
yours
char
Yours
Disclaimer
