Posts_Actions_summaryById |
Get a single post
Catalog: Discourse
Schema: Posts
This is a read-only table function. The Discourse API may not support changing the data or the Invantive UniversalSQL driver for Discourse does not cover it. In the latter case, please use the table NativePlatformScalarRequests to upload data to the Discourse API.
The following parameters can be used to control the behaviour of the table function Posts_Actions_summaryById. A value must be provided at all times for required parameters, but optional parameters in general do not need to have a value and the execution will default to a pre-defined behaviour. Values can be specified by position and by name. In both cases, all parameters not specified will be evaluated using their default values.
Name |
Data Type |
Required |
Default Value |
Documentation |
id |
The columns of the table function Posts_Actions_summaryById are shown below. Each column has an SQL data type.
Name |
Data Type |
Label |
Required |
Documentation |
admin |
char |
Administrator |
avatar_template |
varchar2 |
Avatar Template |
avg_time |
varchar2 |
can_delete |
char |
Can Delete |
can_edit |
char |
Can Edit |
can_recover |
char |
Can Recover |
can_view_edit_history |
char |
Can View Edit History |
can_wiki |
char |
Can Wikify |
cooked |
varchar2 |
Cooked |
created_at |
varchar2 |
Created at |
deleted_at |
varchar2 |
display_username |
varchar2 |
Display User Name |
edit_reason |
varchar2 |
hidden_reason_id |
varchar2 |
hidden |
char |
Hidden |
id |
decimal |
ID |
incoming_link_count |
decimal |
#Incoming Links |
moderator |
char |
Moderator |
name |
varchar2 |
Name |
post_number |
decimal |
Post Number |
post_type |
decimal |
Post Type |
primary_group_flair_bg_color |
varchar2 |
primary_group_flair_color |
varchar2 |
primary_group_flair_url |
varchar2 |
primary_group_name |
varchar2 |
quote_count |
decimal |
#Quotes |
raw |
varchar2 |
Raw |
reads |
decimal |
#Reads |
reply_count |
decimal |
#Replies |
reply_to_post_number |
varchar2 |
score |
decimal |
Score |
staff |
char |
Staff |
topic_id |
decimal |
Topic ID |
topic_slug |
varchar2 |
Topic Slug |
trust_level |
decimal |
Trust Level |
updated_at |
varchar2 |
Updated at |
user_deleted |
char |
User Deleted |
user_id |
decimal |
User ID |
user_title |
varchar2 |
username |
varchar2 |
User Name |
version |
decimal |
Version |
wiki |
char |
Wiki |
yours |
char |
Yours |
