Freshdesk Forums
Navigation: Catalog: Freshdesk > Schemas > Schema: Freshdesk > Tables
products: Freshdesk Products
Catalog: Freshdesk
Schema: Freshdesk
Primary Keys: id
Label: Products
This is a read-only table. The Freshdesk API may not support changing the data or the Invantive UniversalSQL driver for Freshdesk does not cover it. In the latter case, please use the table NativePlatformScalarRequests to upload data to the Freshdesk API.
Table Columns
The columns of the table products are shown below. Each column has an SQL data type.
Name
Data Type
Label
Required
Documentation
created_at
datetime
Created at
Date/time at which the record was created.
description
varchar2
Description
id
int64
ID
name
varchar2
Name
updated_at
datetime
Updated at
Date/time at which the record was last updated.
Disclaimer
