xMsg javascript has not been loaded.
Catalog: Freshdesk
Schema: Freshdesk
Primary Keys: id
Label: Products
This is a read-only table. The Freshdesk API may not support changing the data or the Invantive SQL driver for Freshdesk does not cover it. In the latter case, please use the table NativePlatformScalarRequests to upload data to the Freshdesk API.
Select Freshdesk API URL: /products
Insert Freshdesk API URL: /products
Update Freshdesk API URL: /products
Delete Freshdesk API URL: /products
The columns of the table products are shown below. Each column has an SQL data type.
Name |
Data Type |
Label |
Required |
Documentation |
created_at |
datetime |
Created at |
description |
string |
Description |
id |
int64 |
ID |
name |
string |
Name |
updated_at |
datetime |
Updated at |
12-12-2020 13:14 Version 20.1.301-BETA+3023
