HubSpot Forums
Navigation: Catalog: AccountInfo > Schemas
AccountApiUsageDailyPrivateApps
Retrieve private app daily API usageRetrieve the daily API usage for private apps in the account, along with information about usage limits.
Schema: Basic
This is a read-only table. The HubSpot API may not support changing the data or the Invantive UniversalSQL driver for HubSpot does not cover it. In the latter case, please use the table NativePlatformScalarRequests to upload data to the HubSpot API.
Table Columns
The columns of the table AccountApiUsageDailyPrivateApps are shown below. Each column has an SQL data type.
Name
Data Type
Label
Required
Documentation
collectedAt
datetime
Indicates when the cache was last updated.
currentUsage
int32
How many API calls an account has made for the current day.
fetchStatus
varchar2
Status of fetching the information, including if the data came from the cache.
name
varchar2
Name
Name of the limit type.
resetsAt
datetime
Time that the limit will reset.
usageLimit
int32
Limits by which a single integration can consume the HubSpot public APIs.
Disclaimer
