HubSpot Forums
Navigation: Catalog: AccountInfo > Schemas
AccountDetails
Retrieve account detailsRetrieve account details such as the account type, time zone, currencies, and data hosting location.
Schema: Basic
This is a read-only table. The HubSpot API may not support changing the data or the Invantive UniversalSQL driver for HubSpot does not cover it. In the latter case, please use the table NativePlatformScalarRequests to upload data to the HubSpot API.
Table Columns
The columns of the table AccountDetails are shown below. Each column has an SQL data type.
Name
Data Type
Label
Required
Documentation
accountType
varchar2
Account Type
The type of account, such as APP_DEVELOPER, DEVELOPER_TEST, SANDBOX, or STANDARD.
companyCurrency
varchar2
The primary currency used by the company.
dataHostingLocation
varchar2
The location where the account's data is hosted.
portalId
int32
Portal ID
The unique identifier for the HubSpot account.
timeZone
varchar2
Timezone
The time zone in which the account operates.
uiDomain
varchar2
The domain used for accessing the HubSpot user interface.
utcOffset
varchar2
UTC Offset
The time zone offset from UTC in hours and minutes.
utcOffsetMilliseconds
int64
UTC Offset (ms)
The time zone offset from UTC in milliseconds.
Disclaimer
