HubSpot Forums
Navigation: Catalog: Automation > Schemas
AutomationFlowById
Retrieve a workflowRetrieve the details of a specific automation flow using its unique flow ID.
Catalog: Automation
Schema: Basic
The following parameters can be used to control the behaviour of the table function AutomationFlowById. A value must be provided at all times for required parameters, but optional parameters in general do not need to have a value and the execution will default to a pre-defined behaviour. Values can be specified by position and by name. In both cases, all parameters not specified will be evaluated using their default values.
Name
Data Type
Required
Default Value
Documentation
flowId
The columns of the table function AutomationFlowById are shown below. Each column has an SQL data type.
Name
Data Type
Label
Required
Documentation
canEnrollFromSalesforce
char
createdAt
datetime
Created at
crmObjectCreationStatus
varchar2
customProperties
varchar2
description
varchar2
Description
enrollmentCriteria_listFilterBranch_filterBranchOperator
varchar2
Defines the logical operator used to combine multiple filter branches.
enrollmentCriteria_listFilterBranch_filterBranchType
varchar2
Indicates the type of filter branch, defaulting to OR.
enrollmentCriteria_shouldReEnroll
char
Determines if objects should be re-enrolled when they meet the criteria again.
enrollmentCriteria_type
varchar2
Specifies the type of enrollment criteria, which defaults to 'LIST_BASED'.
enrollmentCriteria_unEnrollObjectsNotMeetingCriteria
char
Indicates whether objects not meeting the criteria should be unenrolled.
enrollmentSchedule_timeOfDay_hour
int32
The hour component of the time, represented as an integer.
enrollmentSchedule_timeOfDay_minute
int32
The minute component of the time, represented as an integer.
enrollmentSchedule_type
varchar2
Specifies the type of enrollment schedule, which is 'DAILY'.
eventAnchor_contactProperty
varchar2
Specifies the contact property associated with the anchor.
eventAnchor_type
varchar2
Indicates the type of the contact property anchor, which defaults to CONTACT_PROPERTY_ANCHOR.
flowType
varchar2
goalFilterBranch_filterBranchOperator
varchar2
goalFilterBranch_filterBranchType
varchar2
id
varchar2
ID
isEnabled
char
name
varchar2
Name
nextAvailableActionId
varchar2
objectTypeId
varchar2
Ojbect Type ID
revisionId
varchar2
Revision ID
startActionId
varchar2
suppressionFilterBranch_filterBranchOperator
varchar2
suppressionFilterBranch_filterBranchType
varchar2
suppressionListIds
varchar2
type
varchar2
Type
unEnrollmentSetting_type
varchar2
Specifies the type of unenrollment setting, with possible values being ALL or SELECTIVE.
updatedAt
datetime
Updated at
uuid
varchar2
Disclaimer
