HubSpot Forums
Navigation: Catalog: Automation > Schemas
AutomationFlowEmailCampaigns
Retrieve workflow email campaignsRetrieve a list of email campaigns associated with automation flows, with optional pagination using 'after', 'before', and 'limit' query parameters.
Catalog: Automation
Schema: Basic
The following parameters can be used to control the behaviour of the table function AutomationFlowEmailCampaigns. A value must be provided at all times for required parameters, but optional parameters in general do not need to have a value and the execution will default to a pre-defined behaviour. Values can be specified by position and by name. In both cases, all parameters not specified will be evaluated using their default values.
Name
Data Type
Required
Default Value
Documentation
after
before
The columns of the table function AutomationFlowEmailCampaigns are shown below. Each column has an SQL data type.
Name
Data Type
Label
Required
Documentation
emailCampaignId
varchar2
Email Campaign ID
The unique identifier for the email campaign associated with the automation flow.
emailContentId
varchar2
The unique identifier for the email content used in the email campaign.
flowId
varchar2
The unique identifier for the automation flow associated with the email campaign.
Disclaimer
