HubSpot Forums
Navigation: Catalog: BlogSettings > Schemas > Schema: Advanced > Tables
BlogSettingRevisionsByBlogId
Get all blog revisionsGet the list of blog revisions. Results can be limited and filtered by creation or updated date.
Schema: Advanced
The following parameters can be used to control the behaviour of the table function BlogSettingRevisionsByBlogId. A value must be provided at all times for required parameters, but optional parameters in general do not need to have a value and the execution will default to a pre-defined behaviour. Values can be specified by position and by name. In both cases, all parameters not specified will be evaluated using their default values.
Name
Data Type
Required
Default Value
Documentation
after
before
blogId
The columns of the table function BlogSettingRevisionsByBlogId are shown below. Each column has an SQL data type.
Name
Data Type
Label
Required
Documentation
id
varchar2
ID
The id of the version.
object_absoluteUrl
varchar2
Blog's root URL
object_allowComments
char
Boolean determining whether or not this blog allows public comments.
object_created
datetime
Object Created at
The timestamp (ISO8601 format) when this blog was created.
object_deletedAt
datetime
Object Deleted at
The timestamp (ISO8601 format) when this Blog was deleted.
object_description
varchar2
The Description of this Blog.
object_htmlTitle
varchar2
Object Title (HTML)
The html title of this Blog.
object_id
varchar2
Object ID
The unique ID of the Blog.
object_language
varchar2
Object Language
The explicitly defined language of the Blog. If null, the Blog will default to the language of the Domain.
object_listingPageId
varchar2
object_name
varchar2
Object Name
The internal name of the blog.
object_publicAccessRulesEnabled
char
Object Public Access Rules Enabled
object_publicTitle
varchar2
The public title of this Blog.
object_slug
varchar2
Object Slug
The path of the this blog. This field is appended to the domain to construct the url of this blog.
object_translatedFromId
varchar2
Object Translated from ID
ID of the primary Blog this object was translated from.
object_updated
datetime
Object Updated at
The timestamp (ISO8601 format) when this blog was updated.
updatedAt
datetime
Updated at
The timestamp (ISO8601 format) when this blog version was updated.
user_email
varchar2
User Email
The email address of the user.
user_fullName
varchar2
User Full Name
The first and last name of the User.
user_id
varchar2
User ID
The unique ID of the User.
Disclaimer
