HubSpot Forums
Navigation: Catalog: Automation > Schemas
AutomationVFlowsPerformanceByFlowId
Catalog: Automation
Schema: Basic
The following parameters can be used to control the behaviour of the table function AutomationVFlowsPerformanceByFlowId. A value must be provided at all times for required parameters, but optional parameters in general do not need to have a value and the execution will default to a pre-defined behaviour. Values can be specified by position and by name. In both cases, all parameters not specified will be evaluated using their default values.
Name
Data Type
Required
Default Value
Documentation
bucketType
Values: DAY, MONTH, WEEK.
end
firstDay
Values: FRIDAY, MONDAY, SATURDAY, SUNDAY, THURSDAY, TUESDAY, WEDNESDAY.
flowId
start
The columns of the table function AutomationVFlowsPerformanceByFlowId are shown below. Each column has an SQL data type.
Name
Data Type
Label
Required
Documentation
bucket
varchar2
frequency
int32
series
varchar2
Disclaimer
