CallingsByAppIdSettings |
Get calling settingsReturns the calling extension settings configured for your app.
Catalog: CallingExtensions3
Schema: Settings
Label: {res:itgen_hubspot_callingsbyappidsettings_plural}
The following parameters can be used to control the behaviour of the table function CallingsByAppIdSettings. A value must be provided at all times for required parameters, but optional parameters in general do not need to have a value and the execution will default to a pre-defined behaviour. Values can be specified by position and by name. In both cases, all parameters not specified will be evaluated using their default values.
Name |
Data Type |
Required |
Default Value |
Documentation |
appId |
int32 |
The ID of the app. |
The columns of the table function CallingsByAppIdSettings are shown below. Each column has an SQL data type.
Name |
Data Type |
Label |
Required |
Documentation |
createdAt |
datetime |
Created at |
When this calling extension was created. |
height |
int32 |
Height |
The target height of the iframe that will contain your phone/calling UI. |
isReady |
boolean |
Is Ready |
When true, this indicates that your calling app is ready for production. Users will be able to select your calling app as their provider and can then click to dial within HubSpot. |
name |
string |
Name |
The name of your calling service to display to users. |
supportsCustomObjects |
boolean |
Supports Custom Objects |
When true, users will be able to click to dial from custom objects. |
supportsInboundCalling |
boolean |
{res:itgen_hubspot_supportsinboundcalling} |
When true, this indicates that your calling app supports inbound calling within HubSpot. |
updatedAt |
datetime |
Updated at |
The last time the settings for this calling extension were modified. |
url |
string |
URL |
The URL to your phone/calling UI, built with the [Calling SDK](#). |
usesCallingWindow |
boolean |
{res:itgen_hubspot_usescallingwindow} |
When false, this indicates that your calling app does not require the use of the separate calling window to hold the call connection. |
width |
int32 |
Width |
The target width of the iframe that will contain your phone/calling UI. |
HubSpot API Data Model
