CallById: HubSpot Call by ID |
ReadRead an Object identified by `{callId}`. `{callId}` refers to the internal object ID by default, or optionally any unique property value as specified by the `idProperty` query param. Control what is returned via the `properties` query param.
Catalog: Calls3
Schema: Basic
Label: Call by ID
The following parameters can be used to control the behaviour of the table function CallById. A value must be provided at all times for required parameters, but optional parameters in general do not need to have a value and the execution will default to a pre-defined behaviour. Values can be specified by position and by name. In both cases, all parameters not specified will be evaluated using their default values.
Name |
Data Type |
Required |
Default Value |
Documentation |
archived |
boolean |
callId |
string |
idProperty |
string |
The name of a property whose values are unique for this object type |
The columns of the table function CallById are shown below. Each column has an SQL data type.
Name |
Data Type |
Label |
Required |
Documentation |
archived |
boolean |
Archived |
archivedAt |
datetime |
Archived at |
associations |
string |
Associations |
createdAt |
datetime |
Created at |
id |
string |
ID |
properties |
string |
Properties |
propertiesWithHistory |
string |
Properties with History |
updatedAt |
datetime |
Updated at |
HubSpot API Data Model
