HubSpot Forums
Navigation: Catalog: Calls > Schemas
CallById2: HubSpot Call by ID
ReadRead an Object identified by `{callId}`. `{callId}` refers to the internal object ID by default, or optionally any unique property value as specified by the `idProperty` query param. Control what is returned via the `properties` query param.
Catalog: Calls
Schema: Basic
Label: Call by ID
The following parameters can be used to control the behaviour of the table function CallById2. A value must be provided at all times for required parameters, but optional parameters in general do not need to have a value and the execution will default to a pre-defined behaviour. Values can be specified by position and by name. In both cases, all parameters not specified will be evaluated using their default values.
Name
Data Type
Required
Default Value
Documentation
archived
callId
idProperty
The name of a property whose values are unique for this object type
The columns of the table function CallById2 are shown below. Each column has an SQL data type.
Name
Data Type
Label
Required
Documentation
archived
char
Archived
archivedAt
datetime
Archived at
associations
varchar2
Associations
createdAt
datetime
Created at
id
varchar2
ID
properties
varchar2
Properties
propertiesWithHistory
varchar2
Properties with History
updatedAt
datetime
Updated at
Disclaimer
