HubSpot Forums
Navigation: Catalog: Calls > Schemas
Calls: HubSpot Calls
ListRead a page of calls. Control what is returned via the `properties` query param.
Catalog: Calls
Schema: Basic
Label: Calls
Retrieve: true
Insert: true
Update: false
Delete: false
The following parameters can be used to control the behaviour of the table function Calls. A value must be provided at all times for required parameters, but optional parameters in general do not need to have a value and the execution will default to a pre-defined behaviour. Values can be specified by position and by name. In both cases, all parameters not specified will be evaluated using their default values.
Name
Data Type
Required
Default Value
Documentation
after
archived
The columns of the table function Calls are shown below. Each column has an SQL data type. A new non-null value must be provided for every required column at all times during insert.
Name
Data Type
Label
Required
Documentation
archived
char
Archived
Whether the object is archived.
archivedAt
datetime
Archived at
The timestamp when the object was archived, in ISO 8601 format.
associations
varchar2
Associations
A list defining relationships with other objects.
createdAt
datetime
Created at
The timestamp when the object was created, in ISO 8601 format.
id
varchar2
ID
The unique ID of the object.
objectWriteTraceId
varchar2
An identifier used for tracing the creation or update request of the object.
prop_hs_activity_type
varchar2
Activity Type
prop_hs_all_accessible_team_ids
varchar2
All Accessible Team IDs
prop_hs_all_assigned_business_unit_ids
varchar2
All Assigned Business Unit IDs
prop_hs_all_owner_ids
varchar2
All Owner IDs
prop_hs_all_team_ids
varchar2
All Team IDs
prop_hs_at_mentioned_owner_ids
varchar2
At Mentioned Owner IDs
prop_hs_attachment_ids
varchar2
Attachment IDs
prop_hs_body_preview_html
varchar2
Body Preview (HTML)
prop_hs_body_preview_is_truncated
char
Body Preview is Truncated
varchar2
Body Preview
prop_hs_call_app_id
decimal
Call App ID
prop_hs_call_authed_url_provider
varchar2
Call Authenticated URL Provider
prop_hs_call_body
varchar2
Call Body
prop_hs_call_callee_object_id
decimal
Call Callee Object ID
prop_hs_call_callee_object_type
varchar2
Call Callee Object Type
prop_hs_call_deal_stage_during_call
varchar2
Call Deal Stage during Call
prop_hs_call_direction
varchar2
Call Direction
prop_hs_call_disposition
varchar2
Call Disposition
prop_hs_call_duration
decimal
Call Duration
prop_hs_call_external_account_id
varchar2
Call External Account ID
prop_hs_call_external_id
varchar2
Call External ID
prop_hs_call_from_number_nickname
varchar2
Call From Number Nickname
varchar2
Call From Number
prop_hs_call_has_transcript
char
Call Has Transcript
prop_hs_call_has_voicemail
varchar2
Call Has Voicemail
prop_hs_call_location
varchar2
prop_hs_call_meeting_event_id
varchar2
prop_hs_call_meeting_id
varchar2
prop_hs_call_ms_teams_payload
varchar2
prop_hs_call_phone_number_source
varchar2
prop_hs_call_primary_deal
varchar2
Call Primary Deal
prop_hs_call_recording_url
varchar2
Call Recording URL
prop_hs_call_routing_strategy_type
varchar2
prop_hs_call_source
varchar2
Call Source
prop_hs_call_status
varchar2
Call Status
prop_hs_call_suggested_next_actions
varchar2
prop_hs_call_summary_execution_id
varchar2
varchar2
prop_hs_call_title
varchar2
Call Title
prop_hs_call_to_number_nickname
varchar2
Call To Number Nickname
varchar2
Call To Number
prop_hs_call_transcript_audio_num_channels
decimal
Call Transcript Audio Number of Channels
prop_hs_call_transcript_tracked_terms
varchar2
Call Transcript Tracked Terms
prop_hs_call_transcription_id
decimal
Call Transcription ID
prop_hs_call_unified_phone_number_id
decimal
prop_hs_call_unique_external_id
varchar2
prop_hs_call_video_meeting_type
varchar2
prop_hs_call_video_recording_url
varchar2
Call Video Recording URL
prop_hs_call_voice_agent_total_ms
decimal
prop_hs_call_zoom_meeting_uuid
varchar2
Call Zoom Meeting UUID
prop_hs_calls_service_call_id
decimal
Calls Service Call ID
prop_hs_campaign_guid
varchar2
prop_hs_connected_count
decimal
Connected Count
prop_hs_created_by_user_id
decimal
Created by User ID
prop_hs_created_by
decimal
Created by
prop_hs_createdate
datetime
Created at
prop_hs_engagement_source_id
varchar2
Engagement Source ID
varchar2
Engagement Source
prop_hs_engagements_last_contacted
datetime
prop_hs_follow_up_action
varchar2
Follow-up Action
prop_hs_gdpr_deleted
char
GDPR Deleted
prop_hs_hosted_video_conference_url
varchar2
prop_hs_lastmodifieddate
datetime
Last Modified Date
prop_hs_merged_object_ids
varchar2
Merged Object IDs
prop_hs_modified_by
decimal
Modified by
prop_hs_obj_coords
varchar2
prop_hs_object_id
decimal
Object ID
prop_hs_object_source_detail_1
varchar2
prop_hs_object_source_detail_2
varchar2
prop_hs_object_source_detail_3
varchar2
prop_hs_object_source_id
varchar2
prop_hs_object_source_label
varchar2
prop_hs_object_source_user_id
decimal
varchar2
prop_hs_owning_teams
varchar2
prop_hs_pinned_engagement_id
decimal
Pinned Engagement ID
prop_hs_product_name
varchar2
Product Name
prop_hs_queue_membership_ids
varchar2
Queue Membership IDs
prop_hs_read_only
char
Read-only
prop_hs_timestamp
datetime
Timestamp
prop_hs_unique_creation_key
varchar2
Unique Creation Key
prop_hs_unique_id
varchar2
Unique ID
prop_hs_unknown_visitor_conversation
char
Unknown Visitor Conversation
prop_hs_updated_by_user_id
decimal
Updated by User ID
prop_hs_user_ids_of_all_notification_followers
varchar2
User IDs of All Notification Followers
prop_hs_user_ids_of_all_notification_unfollowers
varchar2
User IDs of All Notification Unfollowers
prop_hs_user_ids_of_all_owners
varchar2
User IDs of All Owners
prop_hs_voice_agent_is_most_recent_customer_feedback_positive
char
prop_hs_voicemail_count
decimal
Voicemail Count
prop_hs_was_imported
char
Was Imported
prop_hubspot_owner_assigneddate
datetime
Owner Assigned Date
prop_hubspot_owner_id
varchar2
Owner ID
prop_hubspot_team_id
varchar2
Team ID
updatedAt
datetime
Updated at
The timestamp when the object was last updated, in ISO 8601 format.
url
varchar2
URL
The URL on the API that provide direct navigation to the corresponding UI pages for the connectors.
Disclaimer
