HubSpot Forums
Navigation: Catalog: Calls > Schemas
Calls2: HubSpot Calls
ListRead a page of calls. Control what is returned via the `properties` query param.
Catalog: Calls
Schema: Basic
Label: Calls
Retrieve: true
Insert: true
Update: false
Delete: false
The following parameters can be used to control the behaviour of the table function Calls2. A value must be provided at all times for required parameters, but optional parameters in general do not need to have a value and the execution will default to a pre-defined behaviour. Values can be specified by position and by name. In both cases, all parameters not specified will be evaluated using their default values.
Name
Data Type
Required
Default Value
Documentation
after
archived
The columns of the table function Calls2 are shown below. Each column has an SQL data type. A new non-null value must be provided for every required column at all times during insert.
Name
Data Type
Label
Required
Documentation
archived
char
Archived
archivedAt
datetime
Archived at
associations
varchar2
Associations
createdAt
datetime
Created at
id
varchar2
ID
properties
varchar2
Properties
propertiesWithHistory
varchar2
Properties with History
updatedAt
datetime
Updated at
Disclaimer
