ExportAsyncTaskErrorLinesByTaskId |
Get the status of the export including the URL to download the fileReturns the status of the export with taskId, including the URL of the resulting file if the export status is COMPLETE
Catalog: Exports
Schema: Advanced
The following parameters can be used to control the behaviour of the table function ExportAsyncTaskErrorLinesByTaskId. A value must be provided at all times for required parameters, but optional parameters in general do not need to have a value and the execution will default to a pre-defined behaviour. Values can be specified by position and by name. In both cases, all parameters not specified will be evaluated using their default values.
Name |
Data Type |
Required |
Default Value |
Documentation |
taskId |
The columns of the table function ExportAsyncTaskErrorLinesByTaskId are shown below. Each column has an SQL data type.
Name |
Data Type |
Label |
Required |
Documentation |
category |
varchar2 |
Category |
The main category of the error. |
code |
varchar2 |
Code |
The status code associated with the error detail |
completedAt |
datetime |
Completed at |
The timestamp when the export was completed, in ISO 8601 format. |
context_2 |
varchar2 |
Context about the error condition |
context |
varchar2 |
Context |
id |
varchar2 |
ID |
A unique ID for the error instance. |
in |
varchar2 |
In |
The name of the field or parameter in which the error was found. |
links_2 |
varchar2 |
A collection of related links associated with the export. |
links |
varchar2 |
Links |
URLs linking to documentation or resources associated with the error. |
message_2 |
varchar2 |
A human readable message describing the error along with remediation steps where appropriate |
message |
varchar2 |
Message |
numErrors |
int32 |
Number of Errors |
The number of errors encountered during the export process. |
requestedAt |
datetime |
Requested at |
The timestamp when the export request was made, in ISO 8601 format. |
result |
varchar2 |
The URL of the resulting file if the export status is COMPLETE. |
startedAt |
datetime |
Started at |
The timestamp when the export process started, in ISO 8601 format. |
status_2 |
varchar2 |
The current status of the export, which can be PENDING, PROCESSING, COMPLETE or CANCELED. |
status |
varchar2 |
Status |
The HTTP status code associated with the error. |
subCategory_2 |
varchar2 |
A specific category that contains more specific detail about the error |
subCategory |
varchar2 |
Subcategory |
