HubSpot Forums
Navigation: Catalog: Exports > Schemas > Schema: Advanced > Tables
ExportAsyncTaskErrorsByTaskId
Get the status of the export including the URL to download the fileReturns the status of the export with taskId, including the URL of the resulting file if the export status is COMPLETE
Catalog: Exports
Schema: Advanced
The following parameters can be used to control the behaviour of the table function ExportAsyncTaskErrorsByTaskId. A value must be provided at all times for required parameters, but optional parameters in general do not need to have a value and the execution will default to a pre-defined behaviour. Values can be specified by position and by name. In both cases, all parameters not specified will be evaluated using their default values.
Name
Data Type
Required
Default Value
Documentation
taskId
The columns of the table function ExportAsyncTaskErrorsByTaskId are shown below. Each column has an SQL data type.
Name
Data Type
Label
Required
Documentation
category
varchar2
Category
The main category of the error.
completedAt
datetime
Completed at
The timestamp when the export was completed, in ISO 8601 format.
context
varchar2
Context
Context about the error condition
id
varchar2
ID
A unique ID for the error instance.
links_2
varchar2
A collection of related links associated with the export.
links
varchar2
Links
URLs linking to documentation or resources associated with the error.
message
varchar2
Message
A human readable message describing the error along with remediation steps where appropriate
numErrors
int32
Number of Errors
The number of errors encountered during the export process.
requestedAt
datetime
Requested at
The timestamp when the export request was made, in ISO 8601 format.
result
varchar2
The URL of the resulting file if the export status is COMPLETE.
startedAt
datetime
Started at
The timestamp when the export process started, in ISO 8601 format.
status_2
varchar2
The current status of the export, which can be PENDING, PROCESSING, COMPLETE or CANCELED.
status
varchar2
Status
The HTTP status code associated with the error.
subCategory
varchar2
Subcategory
A specific category that contains more specific detail about the error
Disclaimer
