HubSpot Forums
Navigation: Catalog: Posts > Schemas > Schema: Revisions > Tables
BlogPostRevisionsByObjectId
Retrieves all previous versions of a postRetrieve all the previous versions of a blog post.
Catalog: Posts
Schema: Revisions
The following parameters can be used to control the behaviour of the table function BlogPostRevisionsByObjectId. A value must be provided at all times for required parameters, but optional parameters in general do not need to have a value and the execution will default to a pre-defined behaviour. Values can be specified by position and by name. In both cases, all parameters not specified will be evaluated using their default values.
Name
Data Type
Required
Default Value
Documentation
after
before
objectId
The ID of the blog post
The columns of the table function BlogPostRevisionsByObjectId are shown below. Each column has an SQL data type.
Name
Data Type
Label
Required
Documentation
id
varchar2
ID
The id of the version.
object_abStatus
varchar2
Object A/B Status
object_abTestId
varchar2
Object A/B Test ID
object_archivedAt
int64
object_archivedInDashboard
char
Object Archived in Dashboard
object_authorName
varchar2
Object Author Name
object_blogAuthorId
varchar2
Object Blog Author ID
object_campaign
varchar2
Object Campaign
object_categoryId
int32
Object Category ID
object_contentGroupId
varchar2
Object Content Group ID
object_contentTypeCategory
varchar2
Object Content Type Category
object_created
datetime
Object Created at
object_createdById
varchar2
Object Created by ID
object_currentlyPublished
char
Object Currently Published
object_currentState
varchar2
Object Current State
object_domain
varchar2
Object Domain
object_dynamicPageDataSourceId
varchar2
Object Dynamic Page Data Source ID
object_dynamicPageDataSourceType
int32
Object Dynamic Page Data Source Type
object_dynamicPageHubDbTableId
varchar2
object_enableDomainStylesheets
char
Object Enable Domain Stylesheet
object_enableGoogleAmpOutputOverride
char
Object Enable Google AMP Output Override
object_enableLayoutStylesheets
char
Object Enable Layout Stylesheets
object_featuredImage
varchar2
Object Featured Image
object_featuredImageAltText
varchar2
Object Featured Image Alternate Text
object_folderId
varchar2
Object Folder ID
object_footerHtml
varchar2
Object Footer (HTML)
object_headHtml
varchar2
Object Head (HTML)
object_htmlTitle
varchar2
Object Title (HTML)
object_id
varchar2
Object ID
object_includeDefaultCustomCss
char
Object Include Default Custom CSS
object_language
varchar2
Object Language
object_layoutSections
varchar2
Object Layout Sections
object_linkRelCanonicalUrl
varchar2
Object Link Rel Canonical (URL)
object_mabExperimentId
varchar2
Object MAB Experiment ID
object_metaDescription
varchar2
Object Meta Description
object_name
varchar2
Object Name
object_pageExpiryDate
int64
Object Page Expiry Date
object_pageExpiryEnabled
char
Object Page Expiry Enabled
object_pageExpiryRedirectId
int64
Object Page Expiry Redirect ID
object_pageExpiryRedirectUrl
varchar2
Object Page Expiry Redirect URL
object_password
varchar2
Object Password
object_postBody
varchar2
Object Post Body
object_postSummary
varchar2
Object Post Summary
object_publicAccessRulesEnabled
char
Object Public Access Rules Enabled
object_publishDate
datetime
Object Publish Date
object_publishImmediately
char
Object Publish Immediately
object_rssBody
varchar2
Object RSS Body
object_rssSummary
varchar2
Object RSS Summary
object_slug
varchar2
Object Slug
object_state
varchar2(25)
Object State
object_tagIds
varchar2
Object Tag IDs
object_themeSettingsValues
varchar2
Object Theme Setting Values
object_translatedFromId
varchar2
Object Translated from ID
object_translations
varchar2
Object Translations
object_updated
datetime
Object Updated at
object_updatedById
varchar2
Object Updated by ID
object_url
varchar2
Object URL
object_useFeaturedImage
char
Object Use Featured Image
object_widgetContainers
varchar2
Object Widget Containers
object_widgets
varchar2
Object Widgets
updatedAt
datetime
Updated at
The timestamp (ISO8601 format) when this version of the Blog Post was updated.
user_email
varchar2
User Email
The email address of the user.
user_fullName
varchar2
User Full Name
The first and last name of the User.
user_id
varchar2
User ID
The unique ID of the User.
Disclaimer
