BlogPostRevisionsByObjectIdOrRevisionId |
Retrieve a previous version of a blog postRetrieve a previous version of a blog post.
Catalog: Posts
Schema: Revisions
The following parameters can be used to control the behaviour of the table function BlogPostRevisionsByObjectIdOrRevisionId. A value must be provided at all times for required parameters, but optional parameters in general do not need to have a value and the execution will default to a pre-defined behaviour. Values can be specified by position and by name. In both cases, all parameters not specified will be evaluated using their default values.
Name |
Data Type |
Required |
Default Value |
Documentation |
objectId |
The blog post ID |
revisionId |
The ID of the revision to retrieve |
The columns of the table function BlogPostRevisionsByObjectIdOrRevisionId are shown below. Each column has an SQL data type.
Name |
Data Type |
Label |
Required |
Documentation |
id |
varchar2 |
ID |
object_abStatus |
varchar2 |
Object A/B Status |
object_abTestId |
varchar2 |
Object A/B Test ID |
object_archivedAt |
int64 |
object_archivedInDashboard |
char |
Object Archived in Dashboard |
object_authorName |
varchar2 |
Object Author Name |
object_blogAuthorId |
varchar2 |
Object Blog Author ID |
object_campaign |
varchar2 |
Object Campaign |
object_categoryId |
int32 |
Object Category ID |
object_contentGroupId |
varchar2 |
Object Content Group ID |
object_contentTypeCategory |
varchar2 |
Object Content Type Category |
object_created |
datetime |
Object Created at |
object_createdById |
varchar2 |
Object Created by ID |
object_currentlyPublished |
char |
Object Currently Published |
object_currentState |
varchar2 |
Object Current State |
object_domain |
varchar2 |
Object Domain |
object_dynamicPageDataSourceId |
varchar2 |
Object Dynamic Page Data Source ID |
object_dynamicPageDataSourceType |
int32 |
Object Dynamic Page Data Source Type |
object_dynamicPageHubDbTableId |
varchar2 |
object_enableDomainStylesheets |
char |
Object Enable Domain Stylesheet |
object_enableGoogleAmpOutputOverride |
char |
Object Enable Google AMP Output Override |
object_enableLayoutStylesheets |
char |
Object Enable Layout Stylesheets |
object_featuredImage |
varchar2 |
Object Featured Image |
object_featuredImageAltText |
varchar2 |
Object Featured Image Alternate Text |
object_folderId |
varchar2 |
Object Folder ID |
object_footerHtml |
varchar2 |
Object Footer (HTML) |
object_headHtml |
varchar2 |
Object Head (HTML) |
object_htmlTitle |
varchar2 |
Object Title (HTML) |
object_id |
varchar2 |
Object ID |
object_includeDefaultCustomCss |
char |
Object Include Default Custom CSS |
object_language |
varchar2 |
Object Language |
object_layoutSections |
varchar2 |
Object Layout Sections |
object_linkRelCanonicalUrl |
varchar2 |
Object Link Rel Canonical (URL) |
object_mabExperimentId |
varchar2 |
Object MAB Experiment ID |
object_metaDescription |
varchar2 |
Object Meta Description |
object_name |
varchar2 |
Object Name |
object_pageExpiryDate |
int64 |
Object Page Expiry Date |
object_pageExpiryEnabled |
char |
Object Page Expiry Enabled |
object_pageExpiryRedirectId |
int64 |
Object Page Expiry Redirect ID |
object_pageExpiryRedirectUrl |
varchar2 |
Object Page Expiry Redirect URL |
object_password |
varchar2 |
Object Password |
object_postBody |
varchar2 |
Object Post Body |
object_postSummary |
varchar2 |
Object Post Summary |
object_publicAccessRulesEnabled |
char |
Object Public Access Rules Enabled |
object_publishDate |
datetime |
Object Publish Date |
object_publishImmediately |
char |
Object Publish Immediately |
object_rssBody |
varchar2 |
Object RSS Body |
object_rssSummary |
varchar2 |
Object RSS Summary |
object_slug |
varchar2 |
Object Slug |
object_state |
varchar2(25) |
Object State |
object_tagIds |
varchar2 |
Object Tag IDs |
object_themeSettingsValues |
varchar2 |
Object Theme Setting Values |
object_translatedFromId |
varchar2 |
Object Translated from ID |
object_translations |
varchar2 |
Object Translations |
object_updated |
datetime |
Object Updated at |
object_updatedById |
varchar2 |
Object Updated by ID |
object_url |
varchar2 |
Object URL |
object_useFeaturedImage |
char |
Object Use Featured Image |
object_widgetContainers |
varchar2 |
Object Widget Containers |
object_widgets |
varchar2 |
Object Widgets |
updatedAt |
datetime |
Updated at |
user_email |
varchar2 |
User Email |
The email address of the user. |
user_fullName |
varchar2 |
User Full Name |
The first and last name of the User. |
user_id |
varchar2 |
User ID |
The unique ID of the User. |
