BlogPosts: HubSpot Blog Posts |
Get all Blog PostsGet the list of blog posts. Supports paging and filtering. This method would be useful for an integration that examined these models and used an external service to suggest edits.
Catalog: Posts3
Schema: BlogPosts
Label: Blog Posts
Retrieve: true
Insert: true
Update: false
Delete: false
The following parameters can be used to control the behaviour of the table function BlogPosts. A value must be provided at all times for required parameters, but optional parameters in general do not need to have a value and the execution will default to a pre-defined behaviour. Values can be specified by position and by name. In both cases, all parameters not specified will be evaluated using their default values.
Name |
Data Type |
Required |
Default Value |
Documentation |
after |
string |
The cursor token value to get the next set of results. You can get this from the `paging.next.after` JSON property of a paged response containing more results. |
archived |
boolean |
Specifies whether to return deleted Blog Posts. Defaults to `false`. |
createdAfter |
datetime |
Only return Blog Posts created after the specified time. |
createdAt |
datetime |
Only return Blog Posts created at exactly the specified time. |
createdBefore |
datetime |
Only return Blog Posts created before the specified time. |
property |
string |
updatedAfter |
datetime |
Only return Blog Posts last updated after the specified time. |
updatedAt |
datetime |
Only return Blog Posts last updated at exactly the specified time. |
updatedBefore |
datetime |
Only return Blog Posts last updated before the specified time. |
The columns of the table function BlogPosts are shown below. Each column has an SQL data type. A new non-null value must be provided for every required column at all times during insert.
Name |
Data Type |
Label |
Required |
Documentation |
abStatus |
string |
A/B Status |
abTestId |
string |
A/B Test ID |
archivedAt |
int64 |
Archived at |
archivedInDashboard |
boolean |
Archived in Dashboard |
authorName |
string |
Author Name |
blogAuthorId |
string |
Blog Author ID |
campaign |
string |
Campaign |
categoryId |
int32 |
Category ID |
ID of the type of object this is. |
contentGroupId |
string |
Content Group ID |
contentTypeCategory |
string |
Content Type Category |
created |
datetime |
Created at |
createdById |
string |
Created by ID |
currentlyPublished |
boolean |
Currently Published |
currentState |
string |
Current State |
domain |
string |
Domain |
dynamicPageDataSourceId |
string |
Dynamic Page Data Source ID |
dynamicPageDataSourceType |
int32 |
dynamicPageHubDbTableId |
string |
{res:itgen_hubspot_dynamicpagehubdbtableid} |
enableDomainStylesheets |
boolean |
Enable Domain Stylesheets |
boolean |
enableLayoutStylesheets |
boolean |
Enable Layout Stylesheets |
featuredImage |
string |
Featured Image |
featuredImageAltText |
string |
folderId |
string |
Folder ID |
footerHtml |
string |
Footer (HTML) |
headHtml |
string |
Head (HTML) |
htmlTitle |
string |
Title (HTML) |
id |
string |
ID |
includeDefaultCustomCss |
boolean |
Include Default Custom CSS |
language |
string |
Language |
layoutSections |
string |
Layout Sections |
linkRelCanonicalUrl |
string |
Link Rel Canonical (URL) |
mabExperimentId |
string |
MAB Experiment ID |
metaDescription |
string |
Meta Description |
name |
string |
Name |
pageExpiryDate |
int64 |
Page Expiry Date |
pageExpiryEnabled |
boolean |
Page Expiry Enabled |
pageExpiryRedirectId |
int64 |
Page Expiry Redirect ID |
pageExpiryRedirectUrl |
string |
Page Expiry Redirect (URL) |
password |
string |
Password |
postBody |
string |
Post Body |
postSummary |
string |
Post Summary |
publicAccessRulesEnabled |
boolean |
Public Access Rules Enabled |
publishDate |
datetime |
Publish Date |
publishImmediately |
boolean |
Publish Immediately |
rssBody |
string |
RSS Body |
rssSummary |
string |
RSS Summary |
slug |
string |
Slug |
state |
string(25) |
State |
tagIds |
string |
Tag IDs |
themeSettingsValues |
string |
Theme Setting Values |
translatedFromId |
string |
Translated from ID |
translations |
string |
Translations |
updated |
datetime |
Updated at |
updatedById |
string |
Updated by ID |
url |
string |
URL |
useFeaturedImage |
boolean |
Use Featured Image |
widgetContainers |
string |
Widget Containers |
widgets |
string |
Widgets |
