HubSpot Forums
Navigation: Catalog: Posts3 > Schemas
BlogPostsByObjectId: HubSpot Blog Posts by Object ID
Retrieve a Blog PostRetrieve the Blog Post object identified by the id in the path.
Catalog: Posts3
Schema: BlogPosts
Label: Blog Posts by Object ID
The following parameters can be used to control the behaviour of the table function BlogPostsByObjectId. A value must be provided at all times for required parameters, but optional parameters in general do not need to have a value and the execution will default to a pre-defined behaviour. Values can be specified by position and by name. In both cases, all parameters not specified will be evaluated using their default values.
Name
Data Type
Required
Default Value
Documentation
archived
boolean
Specifies whether to return deleted Blog Posts. Defaults to `false`.
objectId
string
The Blog Post id.
property
string
The columns of the table function BlogPostsByObjectId are shown below. Each column has an SQL data type.
Name
Data Type
Label
Required
Documentation
abStatus
string
A/B Status
abTestId
string
A/B Test ID
archivedAt
int64
Archived at
archivedInDashboard
boolean
Archived in Dashboard
authorName
string
Author Name
blogAuthorId
string
Blog Author ID
campaign
string
Campaign
categoryId
int32
Category ID
ID of the type of object this is.
contentGroupId
string
Content Group ID
contentTypeCategory
string
Content Type Category
created
datetime
Created at
createdById
string
Created by ID
currentlyPublished
boolean
Currently Published
currentState
string
Current State
domain
string
Domain
dynamicPageDataSourceId
string
Dynamic Page Data Source ID
dynamicPageDataSourceType
int32
Dynamic Page Data Source Type
dynamicPageHubDbTableId
string
{res:itgen_hubspot_dynamicpagehubdbtableid}
enableDomainStylesheets
boolean
Enable Domain Stylesheets
enableGoogleAmpOutputOverride
boolean
enableLayoutStylesheets
boolean
Enable Layout Stylesheets
featuredImage
string
Featured Image
featuredImageAltText
string
Featured Image Alternate Text
folderId
string
Folder ID
footerHtml
string
Footer (HTML)
headHtml
string
Head (HTML)
htmlTitle
string
Title (HTML)
id
string
ID
includeDefaultCustomCss
boolean
Include Default Custom CSS
language
string
Language
layoutSections
string
Layout Sections
linkRelCanonicalUrl
string
Link Rel Canonical (URL)
mabExperimentId
string
MAB Experiment ID
metaDescription
string
Meta Description
name
string
Name
pageExpiryDate
int64
Page Expiry Date
pageExpiryEnabled
boolean
Page Expiry Enabled
pageExpiryRedirectId
int64
Page Expiry Redirect ID
pageExpiryRedirectUrl
string
Page Expiry Redirect (URL)
password
string
Password
postBody
string
Post Body
postSummary
string
Post Summary
publicAccessRulesEnabled
boolean
Public Access Rules Enabled
publishDate
datetime
Publish Date
publishImmediately
boolean
Publish Immediately
rssBody
string
RSS Body
rssSummary
string
RSS Summary
slug
string
Slug
state
string(25)
State
tagIds
string
Tag IDs
themeSettingsValues
string
Theme Setting Values
translatedFromId
string
Translated from ID
translations
string
Translations
updated
datetime
Updated at
updatedById
string
Updated by ID
url
string
URL
useFeaturedImage
boolean
Use Featured Image
widgetContainers
string
Widget Containers
widgets
string
Widgets
Disclaimer
