CrmObjectsVProjectsByProjectId |
ReadRead an Object identified by `{projectId}`. `{projectId}` refers to the internal object ID by default, or optionally any unique property value as specified by the `idProperty` query param. Control what is returned via the `properties` query param.
Catalog: Projects
Schema: Basic
The following parameters can be used to control the behaviour of the table function CrmObjectsVProjectsByProjectId. A value must be provided at all times for required parameters, but optional parameters in general do not need to have a value and the execution will default to a pre-defined behaviour. Values can be specified by position and by name. In both cases, all parameters not specified will be evaluated using their default values.
Name |
Data Type |
Required |
Default Value |
Documentation |
archived |
idProperty |
The name of a property whose values are unique for this object type |
projectId |
The columns of the table function CrmObjectsVProjectsByProjectId are shown below. Each column has an SQL data type.
Name |
Data Type |
Label |
Required |
Documentation |
archived |
char |
Archived |
Whether the object is archived. |
archivedAt |
datetime |
Archived at |
The timestamp when the object was archived, in ISO 8601 format. |
associations |
varchar2 |
Associations |
A list defining relationships with other objects. |
createdAt |
datetime |
Created at |
The timestamp when the object was created, in ISO 8601 format. |
id |
varchar2 |
ID |
The unique ID of the object. |
objectWriteTraceId |
varchar2 |
An identifier used for tracing the creation or update request of the object. |
properties |
varchar2 |
Properties |
Key value pairs representing the properties of the object. |
propertiesWithHistory |
varchar2 |
Properties with History |
Key-value pairs representing the properties of the object along with their history. |
updatedAt |
datetime |
Updated at |
The timestamp when the object was last updated, in ISO 8601 format. |
url |
varchar2 |
URL |
The URL on the API that provide direct navigation to the corresponding UI pages for the connectors. |
