HubSpot Forums
Navigation: Catalog: Properties > Schemas > Schema: Basic > Tables
PropertyGroupNamesByObjectType: HubSpot
Read a property groupRead a property group identified by {groupName}.
Catalog: Properties
Schema: Basic
The following parameters can be used to control the behaviour of the table function PropertyGroupNamesByObjectType. A value must be provided at all times for required parameters, but optional parameters in general do not need to have a value and the execution will default to a pre-defined behaviour. Values can be specified by position and by name. In both cases, all parameters not specified will be evaluated using their default values.
Name
Data Type
Required
Default Value
Documentation
groupName
locale
objectType
The columns of the table function PropertyGroupNamesByObjectType are shown below. Each column has an SQL data type.
Name
Data Type
Label
Required
Documentation
archived
char
Archived
Indicates whether the property group is archived.
displayOrder
int32
Display Order
Property groups are displayed in order starting with the lowest positive integer value. Values of -1 will cause the property group to be displayed after any positive values.
label
varchar2
Label
A human-readable label that will be shown in HubSpot.
name
varchar2
Name
The internal property group name, which must be used when referencing the property group via the API.
Disclaimer
