PropertyGroupsByObjectType: HubSpot Property Groups by Object Type |
Read all property groupsRead all existing property groups for the specified object type and HubSpot account.
Catalog: Properties
Schema: Basic
Label: Property Groups by Object Type
The following parameters can be used to control the behaviour of the table function PropertyGroupsByObjectType. A value must be provided at all times for required parameters, but optional parameters in general do not need to have a value and the execution will default to a pre-defined behaviour. Values can be specified by position and by name. In both cases, all parameters not specified will be evaluated using their default values.
Name |
Data Type |
Required |
Default Value |
Documentation |
locale |
objectType |
The columns of the table function PropertyGroupsByObjectType are shown below. Each column has an SQL data type.
Name |
Data Type |
Label |
Required |
Documentation |
archived |
char |
Archived |
Indicates whether the property group is archived. |
displayOrder |
int32 |
Display Order |
Property groups are displayed in order starting with the lowest positive integer value. Values of -1 will cause the property group to be displayed after any positive values. |
label |
varchar2 |
Label |
A human-readable label that will be shown in HubSpot. |
name |
varchar2 |
Name |
The internal property group name, which must be used when referencing the property group via the API. |
