BlogTags: HubSpot Blog Tags |
Get all Blog TagsGet the list of blog tags. Supports paging and filtering. This method would be useful for an integration that examined these models and used an external service to suggest edits.
Catalog: Tags
Schema: Basic
Label: Blog Tags
Retrieve: true
Insert: true
Update: false
Delete: false
The following parameters can be used to control the behaviour of the table function BlogTags. A value must be provided at all times for required parameters, but optional parameters in general do not need to have a value and the execution will default to a pre-defined behaviour. Values can be specified by position and by name. In both cases, all parameters not specified will be evaluated using their default values.
Name |
Data Type |
Required |
Default Value |
Documentation |
after |
archived |
createdAfter |
createdAt |
createdBefore |
property |
updatedAfter |
updatedAt |
updatedBefore |
The columns of the table function BlogTags are shown below. Each column has an SQL data type. A new non-null value must be provided for every required column at all times during insert.
Name |
Data Type |
Label |
Required |
Documentation |
created |
datetime |
Created at |
The timestamp (ISO8601 format) when this Blog Tag was created. |
deletedAt |
datetime |
Deleted at |
The timestamp (ISO8601 format) when this Blog Tag was deleted. |
id |
varchar2 |
ID |
The unique ID of the Blog Tag. |
language |
varchar2 |
Language |
The explicitly defined ISO 639 language code of the tag. |
name |
varchar2 |
Name |
The name of the tag. |
slug |
varchar2 |
Slug |
translatedFromId |
int64 |
Translated from ID |
ID of the primary tag this object was translated from. |
updated |
datetime |
Updated at |
The timestamp (ISO8601 format) when this Blog Tag was updated. |
