HubSpot Forums
Navigation: Catalog: Tags > Schemas
BlogTagsByObjectId: HubSpot Blog Tags by Object ID
Retrieve a Blog TagRetrieve the Blog Tag object identified by the id in the path.
Catalog: Tags
Schema: Basic
Label: Blog Tags by Object ID
The following parameters can be used to control the behaviour of the table function BlogTagsByObjectId. A value must be provided at all times for required parameters, but optional parameters in general do not need to have a value and the execution will default to a pre-defined behaviour. Values can be specified by position and by name. In both cases, all parameters not specified will be evaluated using their default values.
Name
Data Type
Required
Default Value
Documentation
archived
objectId
property
The columns of the table function BlogTagsByObjectId are shown below. Each column has an SQL data type.
Name
Data Type
Label
Required
Documentation
created
datetime
Created at
The timestamp (ISO8601 format) when this Blog Tag was created.
deletedAt
datetime
Deleted at
The timestamp (ISO8601 format) when this Blog Tag was deleted.
id
varchar2
ID
The unique ID of the Blog Tag.
language
varchar2
Language
The explicitly defined ISO 639 language code of the tag.
name
varchar2
Name
The name of the tag.
slug
varchar2
Slug
translatedFromId
int64
Translated from ID
ID of the primary tag this object was translated from.
updated
datetime
Updated at
The timestamp (ISO8601 format) when this Blog Tag was updated.
Disclaimer
