HubSpot Forums
Navigation: Catalog: Users > Schemas
UserById
ReadRead an Object identified by `{userId}`. `{userId}` refers to the internal object ID by default, or optionally any unique property value as specified by the `idProperty` query param. Control what is returned via the `properties` query param.
Catalog: Users
Schema: Basic
The following parameters can be used to control the behaviour of the table function UserById. A value must be provided at all times for required parameters, but optional parameters in general do not need to have a value and the execution will default to a pre-defined behaviour. Values can be specified by position and by name. In both cases, all parameters not specified will be evaluated using their default values.
Name
Data Type
Required
Default Value
Documentation
archived
idProperty
The name of a property whose values are unique for this object type
userId
The columns of the table function UserById are shown below. Each column has an SQL data type.
Name
Data Type
Label
Required
Documentation
archived
char
Archived
Whether the object is archived.
archivedAt
datetime
Archived at
The timestamp when the object was archived, in ISO 8601 format.
associations
varchar2
Associations
A list defining relationships with other objects.
createdAt
datetime
Created at
The timestamp when the object was created, in ISO 8601 format.
id
varchar2
ID
The unique ID of the object.
objectWriteTraceId
varchar2
An identifier used for tracing the creation or update request of the object.
properties
varchar2
Properties
Key value pairs representing the properties of the object.
propertiesWithHistory
varchar2
Properties with History
Key-value pairs representing the properties of the object along with their history.
updatedAt
datetime
Updated at
The timestamp when the object was last updated, in ISO 8601 format.
url
varchar2
URL
The URL on the API that provide direct navigation to the corresponding UI pages for the connectors.
Disclaimer
