HubSpot Forums
Navigation: Catalog: Users > Schemas
Users
ListRead a page of users. Control what is returned via the `properties` query param.
Catalog: Users
Schema: Basic
Retrieve: true
Insert: true
Update: false
Delete: false
The following parameters can be used to control the behaviour of the table function Users. A value must be provided at all times for required parameters, but optional parameters in general do not need to have a value and the execution will default to a pre-defined behaviour. Values can be specified by position and by name. In both cases, all parameters not specified will be evaluated using their default values.
Name
Data Type
Required
Default Value
Documentation
after
archived
The columns of the table function Users are shown below. Each column has an SQL data type. A new non-null value must be provided for every required column at all times during insert.
Name
Data Type
Label
Required
Documentation
archived
char
Archived
Whether the object is archived.
archivedAt
datetime
Archived at
The timestamp when the object was archived, in ISO 8601 format.
associations
varchar2
Associations
A list defining relationships with other objects.
createdAt
datetime
Created at
The timestamp when the object was created, in ISO 8601 format.
id
varchar2
ID
The unique ID of the object.
objectWriteTraceId
varchar2
An identifier used for tracing the creation or update request of the object.
properties
varchar2
Properties
Key value pairs representing the properties of the object.
propertiesWithHistory
varchar2
Properties with History
Key-value pairs representing the properties of the object along with their history.
updatedAt
datetime
Updated at
The timestamp when the object was last updated, in ISO 8601 format.
url
varchar2
URL
The URL on the API that provide direct navigation to the corresponding UI pages for the connectors.
Disclaimer
