Users |
ListRead a page of users. Control what is returned via the `properties` query param.
Catalog: Users3
Schema: Basic
Label: {res:itgen_hubspot_users_plural}
The following parameters can be used to control the behaviour of the table function Users. A value must be provided at all times for required parameters, but optional parameters in general do not need to have a value and the execution will default to a pre-defined behaviour. Values can be specified by position and by name. In both cases, all parameters not specified will be evaluated using their default values.
Name |
Data Type |
Required |
Default Value |
Documentation |
after |
string |
archived |
boolean |
The columns of the table function Users are shown below. Each column has an SQL data type.
Name |
Data Type |
Label |
Required |
Documentation |
archived |
boolean |
Archived |
archivedAt |
datetime |
Archived at |
associations |
string |
Associations |
createdAt |
datetime |
Created at |
id |
string |
ID |
properties |
string |
Properties |
propertiesWithHistory |
string |
Properties with History |
updatedAt |
datetime |
Updated at |
HubSpot API Data Model
