VideoconferencingSettingsByAppId |
Get settingsReturn the settings for a video conference application with the specified ID.
Catalog: VideoConferencingExtension3
Schema: Settings
Label: {res:itgen_hubspot_videoconferencingsettingsbyappid_plural}
The following parameters can be used to control the behaviour of the table function VideoconferencingSettingsByAppId. A value must be provided at all times for required parameters, but optional parameters in general do not need to have a value and the execution will default to a pre-defined behaviour. Values can be specified by position and by name. In both cases, all parameters not specified will be evaluated using their default values.
Name |
Data Type |
Required |
Default Value |
Documentation |
appId |
int32 |
The ID of the video conference application. This is the identifier of the application created in your HubSpot developer portal. |
The columns of the table function VideoconferencingSettingsByAppId are shown below. Each column has an SQL data type.
Name |
Data Type |
Label |
Required |
Documentation |
createMeetingUrl |
string |
Create Meeting (URL) |
The URL that HubSpot will send requests to create a new video conference. |
deleteMeetingUrl |
string |
Delete Meeting (URL) |
The URL that HubSpot will send notifications of meetings that have been deleted in HubSpot. |
fetchAccountsUri |
string |
{res:itgen_hubspot_fetchaccountsuri} |
updateMeetingUrl |
string |
Update Meeting (URL) |
The URL that HubSpot will send updates to existing meetings. Typically called when the user changes the topic or times of a meeting. |
userVerifyUrl |
string |
User Verify (URL) |
The URL that HubSpot will use to verify that a user exists in the video conference application. |
HubSpot API Data Model
