WebhooksByAppIdSettings |
Read webhook settingsRetrieve the webhook settings for the specified app, including the webhook’s target URL, throttle configuration, and create/update date.
Catalog: Webhooks3
Schema: Settings
Label: {res:itgen_hubspot_webhooksbyappidsettings_plural}
The following parameters can be used to control the behaviour of the table function WebhooksByAppIdSettings. A value must be provided at all times for required parameters, but optional parameters in general do not need to have a value and the execution will default to a pre-defined behaviour. Values can be specified by position and by name. In both cases, all parameters not specified will be evaluated using their default values.
Name |
Data Type |
Required |
Default Value |
Documentation |
appId |
int32 |
The ID of the app. |
The columns of the table function WebhooksByAppIdSettings are shown below. Each column has an SQL data type.
Name |
Data Type |
Label |
Required |
Documentation |
createdAt |
datetime |
Created at |
When this subscription was created. Formatted as milliseconds from the [Unix epoch](#). |
targetUrl |
string |
Target (URL) |
A publicly available URL for HubSpot to call where event payloads will be delivered. See [link-so-some-doc](#) for details about the format of these event payloads. |
throttling_maxConcurrentRequests |
int32 |
Throttling Max Concurrent Requests |
The maximum number of concurrent HTTP requests HubSpot will attempt to make to your app. |
updatedAt |
datetime |
Updated at |
When this subscription was last updated. Formatted as milliseconds from the [Unix epoch](#). |
HubSpot API Data Model
